jQuery UI Widgets Forums Lists ComboBox jqxComboBox maxRows per input data
This topic contains 5 replies, has 2 voices, and was last updated by  Rodrigo 12 years, 7 months ago.
  • jqxComboBox maxRows per input data #8845
    Rodrigo
    Hi Guys,
    I have just started using jqxComboBox in “remote search” mode which is working great! and i’ve worked out how to initialise the box with a blank value by setting “selectedIndex: -1”. This will allow the user to type what ever they wish.
    Problem i’m having is with “maxRows” I have set it to “6” but i’m still getting all 20 products listed (testing products). Potentially i will have hundreds/thousands of products… and cannot load all in one go. I have set a limit of “6” in my query, but it doesn’t seem to call the database on re-enter of another product.
    I’m sure i’m doing something silly somewhere, your help is much appreciated!
    Rodrigo
    jqxComboBox maxRows per input data #8859
    Hi Rodrigo,
    How do you handle the “maxRows” field in your server script? Do you limit your query like MySQL’s LIMIT ? Could you provide additional details and a code snippet regarding your scenario and your server side code?
    jqxComboBox maxRows per input data #8885
    Rodrigo
    Thank your prompt reply.
    Yes i’m using mysql limit e.g:
    $maxRows = $_GET[‘maxRows’];
    select * from products where productcode like ‘%$searchstring%’ limit $maxRows;
    Rodrigo
    jqxComboBox maxRows per input data #8896
    Hi Rodrigo,
    If this does not work, then may be the $maxRows value is not Ok. I suggest you for test purposes to hard-code your $maxRows value in your query to 6. Your server script will be called each time the following is executed:
                    search: function (searchString) {
    dataAdapter.dataBind();
    In addition, you can disable the Ajax caching by setting the source’s object’s ‘cache’ field to false.
    jqxComboBox maxRows per input data #8901
    Rodrigo
    That’s great thank you! I’ll give it a whirl today 🙂
    Rodrigo
    jqxComboBox maxRows per input data #9009
    Rodrigo
    It turned out that I was running jqwidgets “2.1” I’ve now upgraded to the lastest “2.4.2” and all is well 🙂 just in case anyone else comes across a similar issue.
    Rodrigo
