jQuery UI Widgets › Forums › Angular › JQXChart problem
This topic contains 4 replies, has 2 voices, and was last updated by rjwijnen 8 years, 3 months ago.
AuthorJQXChart problem Posts
I’m trying to get an working example of the JQXChart but i am getting the following errors:
Error at C:/Projecten/BMO KPIs/Angular2WebpackVisualStudioHZ/src/Angular2WebpackVisualStudio/node_modules/jqwidgets-framework/jqwidgets-ts/angular_jqxchart.ts:70:22: Property 'attrWidth' does not exist on type 'SimpleChanges'. Error at C:/Projecten/BMO KPIs/Angular2WebpackVisualStudioHZ/src/Angular2WebpackVisualStudio/node_modules/jqwidgets-framework/jqwidgets-ts/angular_jqxchart.ts:70:43: Property 'attrHeight' does not exist on type 'SimpleChanges'.
Any idea’s why this is going wrong?
Component:
/// <reference path="../../../../node_modules/jqwidgets-framework/jqwidgets-ts/jqwidgets.d.ts" /> import { Component } from '@angular/core'; import { jqxChartComponent } from '../../../../node_modules/jqwidgets-framework/jqwidgets-ts/angular_jqxchart'; @Component({ selector: 'ecverloop-component', template:
<jqxChart [width]=’850′ [height]=’500′
[title]=’title’ [description]=’description’ [showLegend]=’true’
[enableAnimations]=’true’ [padding]=’padding’ [titlePadding]=’titlePadding’
[source]=’sampleData’ [xAxis]=’xAxis’ [colorScheme]='”scheme01″‘
[seriesGroups]=’seriesGroups’>
</jqxChart>`
})export class ECVerloopComponent {
sampleData = [
{ Day: ‘Monday’, Keith: 30, Erica: 15, George: 25 },
{ Day: ‘Tuesday’, Keith: 25, Erica: 25, George: 30 },
{ Day: ‘Wednesday’, Keith: 30, Erica: 20, George: 25 },
{ Day: ‘Thursday’, Keith: 35, Erica: 25, George: 45 },
{ Day: ‘Friday’, Keith: 20, Erica: 20, George: 25 },
{ Day: ‘Saturday’, Keith: 30, Erica: 20, George: 30 },
{ Day: ‘Sunday’, Keith: 60, Erica: 45, George: 90 }
title: string = “Fitness & exercise weekly scorecard”;
description: string = “Time spent in vigorous exercise”;
padding: any = { left: 5, top: 5, right: 5, bottom: 5 };
titlePadding: any = { left: 90, top: 0, right: 0, bottom: 10 };
xAxis: any =
dataField: ‘Day’,
gridLines: {
visible: true
seriesGroups: any[] =
type: ‘column’,
columnsGapPercent: 50,
seriesGapPercent: 0,
valueAxis:
unitInterval: 10,
minValue: 0,
maxValue: 100,
displayValueAxis: true,
description: ‘Time in minutes’,
axisSize: ‘auto’,
tickMarksColor: ‘#888888’
series: [
{ dataField: ‘Keith’, displayText: ‘Keith’ },
{ dataField: ‘Erica’, displayText: ‘Erica’ },
{ dataField: ‘George’, displayText: ‘George’ }
}`Package.json:
{ "name": "angular2-webpack-visualstudio", "version": "1.0.0", "description": "", "main": "wwwroot/index.html", "author": "", "license": "ISC", "scripts": { "ngc": "ngc -p ./tsconfig-aot.json", "start": "concurrently \"webpack-dev-server --hot --inline --port 8080\" \"dotnet run\" ", "webpack-dev": "set NODE_ENV=development && webpack", "webpack-production": "set NODE_ENV=production && webpack", "build-dev": "npm run webpack-dev", "build-production": "npm run ngc && npm run webpack-production", "watch-webpack-dev": "set NODE_ENV=development && webpack --watch --color", "watch-webpack-production": "npm run build-production --watch --color", "publish-for-iis": "npm run build-production && dotnet publish -c Release" }, "dependencies": { "@angular/common": "~2.4.6", "@angular/compiler": "~2.4.6", "@angular/core": "~2.4.6", "@angular/forms": "~2.4.6", "@angular/http": "~2.4.6", "@angular/platform-browser": "~2.4.6", "@angular/platform-browser-dynamic": "~2.4.6", "@angular/router": "~3.4.6", "@angular/upgrade": "~2.4.6", "angular-in-memory-web-api": "0.2.4", "core-js": "2.4.1", "reflect-metadata": "0.1.9", "rxjs": "5.0.3", "zone.js": "0.7.6", "@angular/compiler-cli": "~2.4.6", "@angular/platform-server": "~2.4.6", "bootstrap": "^3.3.7", "ie-shim": "~0.1.0", "ng2-adal": "0.2.8", "angular2-adal": "0.1.4", "angular2-platform-node": "~2.0.10", "angular2-universal": "~2.0.10", "angular2-universal-polyfills": "~2.0.10", "jqwidgets-framework": "4.5.0" }, "devDependencies": { "@types/node": "7.0.0", "angular2-template-loader": "0.6.0", "angular-router-loader": "^0.5.0", "awesome-typescript-loader": "^2.2.4", "clean-webpack-plugin": "^0.1.15", "concurrently": "^3.1.0", "copy-webpack-plugin": "^4.0.1", "css-loader": "^0.26.1", "file-loader": "^0.9.0", "html-webpack-plugin": "^2.26.0", "jquery": "^2.2.0", "json-loader": "^0.5.4", "node-sass": "^4.3.0", "raw-loader": "^0.5.1", "rimraf": "^2.5.4", "sass-loader": "^4.1.1", "script-loader": "0.7.0", "source-map-loader": "^0.1.6", "style-loader": "^0.13.1", "ts-helpers": "^1.1.2", "tslint": "^4.3.1", "tslint-loader": "^3.3.0", "typescript": "2.0.3", "url-loader": "^0.5.7", "webpack": "^2.2.1", "webpack-dev-server": "2.2.1" }, "-vs-binding": { "ProjectOpened": [ "watch-webpack-dev" ] } }
Hi rjwijnen,
Thanks for the report. This will be fixed in the next release. For now change the following line of code(line 70 in the angular_jqxchart.ts file) to:
if (changes.hasOwnProperty('attrWidth') || changes.hasOwnProperty('attrHeight')) {
IvojQWidgets Team
http://www.jqwidgets.com/Now i am getting the following error when using AOT build (the build succeeds but when opening the page this error occured, normal build without AOT shows the chart oke and no errors) :
TypeError: this.host.jqxChart is not a function
Hi rjwijnen,
Can you please debug it and tell me exactly on which line of angular_jqxchart.ts that error occurs. And ofcourse with what do you cause it.
IvojQWidgets Team
http://www.jqwidgets.com/My excuses, i think i found the problem. In my webpack config i had the commonchunkplugin configured also for the jqw js files. I my dev. config i did not have this.
