jQuery UI Widgets › Forums › Plugins › AngularJS › jqxAngular Grid scripts does not fire
This topic contains 2 replies, has 2 voices, and was last updated by Peter Stoev 10 years, 1 month ago.
Following the jqxAngular demo and the Grid with scripts loaded on demand section, I’m not able to fire the radioboxes checked events when utilized for the grid built in this code:
<html ng-app=”demoApp”>
<title id=”Description”>jqxGrid Binding to JSON using AngularJS</title>
<link rel=”stylesheet” type=”text/css” href=”../../jqwidgets/styles/jqx.base.css” />
<script type=”text/javascript” src=”../../jqwidgets/scripts/angular.min.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/scripts/jquery-1.11.1.min.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/jqxradiobutton.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/jqxgrid.edit.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/jqxgrid.filter.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/jqxgrid.sort.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/jqxgrid.columnsresize.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/jqxangular.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/scripts/demos.js”></script>
var demoApp = angular.module(“demoApp”, [“jqwidgets”]);
demoApp.controller(“demoController”, function ($scope, $http) {
$scope.createWidget = false;
$http({
method: ‘get’,
url: ‘../../concrete/themes/elemental/domains/grid_data.php’
}).success(function (data, status) {
var source = {
{ name: ‘Code’},
{ name: ‘Name’}
localdata: data,
commit(true);
commit(true);
commit(true);
$scope.gridSettings = {
width: 500,
showfilterrow: true,
{ text: ‘Code’, filtertype: ‘input’, datafield: ‘Code’, width: 250 },
{ text: ‘Name’, filtertype: ‘input’, datafield: ‘Name’, width: 250 }
$scope.createWidget = true;
}).error(function (data, status) {
// Some error occurred
var setAlignment = function (align) {
$scope.gridSettings.apply(‘beginupdate’);
for (var index = 0; index < columns.length; index++) {
$scope.gridSettings.apply(‘setcolumnproperty’, columns[index].datafield, ‘align’, align);
$scope.gridSettings.apply(‘setcolumnproperty’, columns[index].datafield, ‘cellsAlign’, align);
$scope.gridSettings.apply(‘endupdate’);
$scope.leftCheck = function () {
setAlignment(‘left’);
$scope.centerCheck = function () {
setAlignment(‘center’);
$scope.rightCheck = function () {
setAlignment(‘right’);
<body ng-controller=”demoController”>
<jqx-grid jqx-create=”createWidget” jqx-settings=”gridSettings”></jqx-grid>
<div>
<h3>Alignment</h3>
<jqx-radio-button jqx-width=”100″ style=”float: left;” jqx-on-checked=”leftCheck(event)”>Left</jqx-radio-button>
<jqx-radio-button jqx-checked=”true” jqx-width=”100″ style=”float: left;” jqx-on-checked=”centerCheck(event)”>Center</jqx-radio-button>
<jqx-radio-button jqx-width=”100″ style=”float: left;” jqx-on-checked=”rightCheck(event)”>Right</jqx-radio-button>
</html>The radioboxes checked events are found to be fired, when a test alert is inserted.
What is not run, is the setAlignment function called.
Hi Ivalde,
The demo is available online and it works correctly – http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxangular/angularjs-grid-alignment.htm
