jQuery UI Widgets › Forums › Plugins › AngularJS › jqx-instance using ngController scope-property syntax
This topic contains 7 replies, has 3 voices, and was last updated by cenergistic 10 years, 6 months ago.
How do we use the “jqx-instance” attribute directive when used with the ngController scope-property syntax: “Controller as myController”?
see: Angular Docs on ngControllerfor example, this does not work as it should:
<div ng-controller="MainController as main"> <jqx-button jqx-instance="main.myButton"></jqx-button> </div>
in the controller,
this.myButton
should point to the instance, but it is undefined!And please don’t tell me to use the other declaration style, i.e., by injecting “$scope” into the controller. With more complex applications we need the more specific syntax to promote clarity, isolation, modularity, etc., especially when coming from multiple developers.
Thank you
I looked into the source and the ngController scope-property syntax is not supported… but it’s easy enough to fix (see jqxangular.js:278). And such a fix falls within the terms of the jqWidgets EULA… although I can’t post any code here. If the admin folks (Hi Peter!) want to see my changes, please email me!
By the way, I always find the source to be so clean and simple… nice job Peter Stoev and the team.
Hi Fire613,
Don’t know how you implemented it, but I suppose you used $parse
http://www.jqwidgets.comI am having the same issue how do I fix this?
I am trying to use a variable chart settings. on my controller where I have the controller as syntax
<jqx-chart jqx-settings="chartSettings" jqx-watch-settings jqx-ng-model style="width: 100%; height:550px;"></jqx-chart>
cal.chartSettings = { title: "24HR Period of Data", description: "Kilowatts per Hour", showLegend: true, source: dataAdapter, enableAnimations: true, padding: { left: 5, top: 5, right: 50, bottom: 5 }, titlePadding: { left: 90, top: 0, right: 0, bottom: 10 }, xAxis: { dataField: 'HR', showGridLines: true }, colorScheme: 'scheme01', seriesGroups: [ { type: 'column', columnsGapPercent: 50, valueAxis: { unitInterval: 350, displayValueAxis: true, description: 'KW' }, series: [ { dataField: 'KW', displayText: 'KW/H', colorFunction: function (value, itemIndex, serie, group) { return (value > 100) ? '#CC1133' : '#55CC55'; } }, ] } ], bindingcomplete: function (event) { alert("binding is completed"); } };
Please, provide a small .htm page sample which illustrates your issue. Also check whether you use jQWidgets 3.6.0. I also don’t see in your code how you refer to your controller or the settings defined in it.
http://www.jqwidgets.com/Below is a modified version of the chart sample. thanks for your help
<!DOCTYPE html> <html ng-app="demoApp"> <head> <title id="Description">jqxChart directive for AngularJS</title> <link rel="stylesheet" type="text/css" href="/jqwidgetsangular/styles/jqx.base.css" /> <script type="text/javascript" src="//ajax.googleapis.com/ajax/libs/jquery/2.1.1/jquery.min.js"></script> <script type="text/javascript" src="//ajax.googleapis.com/ajax/libs/angularjs/1.2.26/angular.min.js"></script> <script type="text/javascript" src="/jqwidgetsangular/scripts/jqxcore.js"></script> <script type="text/javascript" src="/jqwidgetsangular/scripts/jqxdata.js"></script> <script type="text/javascript" src="/jqwidgetsangular/scripts/jqxbuttons.js"></script> <script type="text/javascript" src="/jqwidgetsangular/scripts/jqxdraw.js"></script> <script type="text/javascript" src="/jqwidgetsangular/scripts/jqxchart.core.js"></script> <script type="text/javascript" src="/jqwidgetsangular/scripts/jqxangular.js"></script> <script type="text/javascript"> var demoApp = angular.module("demoApp", ["jqwidgets"]); demoApp.controller("demoController", demoController); function demoController() { var dm = this; dm.dataAdapter = new $.jqx.dataAdapter( { datatype: "csv", datafields: [ { name: 'Country' }, { name: 'GDP' }, { name: 'DebtPercent' }, { name: 'Debt' } ], url: '/jqwidgetsangular/sampledata/gdp_dept_2010.txt' }, { async: false, autoBind: true, loadError: function (xhr, status, error) { alert('Error loading "' + source.url + '" : ' + error); } }); dm.setLineChartType = setLineChartType(); // prepare jqxChart settings dm.chartSettings = { title: "Economic comparison", description: "GDP and Debt in 2010", showLegend: true, enableAnimations: true, padding: { left: 5, top: 5, right: 50, bottom: 5 }, titlePadding: { left: 90, top: 0, right: 0, bottom: 10 }, source: dm.dataAdapter, xAxis: { dataField: 'Country', showGridLines: true }, colorScheme: 'scheme01', seriesGroups: [ { type: 'column', columnsGapPercent: 50, valueAxis: { unitInterval: 5000, displayValueAxis: true, description: 'GDP & Debt per Capita($)' }, series: [ { dataField: 'GDP', displayText: 'GDP per Capita' }, { dataField: 'Debt', displayText: 'Debt per Capita' } ] }, { type: 'line', valueAxis: { unitInterval: 10, displayValueAxis: false, description: 'Debt (% of GDP)' }, series: [ { dataField: 'DebtPercent', displayText: 'Debt (% of GDP)' } ] } ] }; function setLineChartType() { dm.chartSettings.seriesGroups[0].type = 'line'; } }; </script> </head> <body> <div data-ng-controller="demoController as dm"> <jqx-chart jqx-settings="dm.chartSettings" jqx-watch="dm.chartSettings.seriesGroups" style="width: 850px; height: 500px;"></jqx-chart> <br /> <jqx-button jqx-on-click="dm.setLineChartType()">Set Line Chart Type</jqx-button> </div> </body> </html>
Hi cenergistic,
The problems in the provided code are syntax errors.
Corrected code below:
<!DOCTYPE html> <html ng-app="demoApp"> <head> <title id="Description">jqxChart directive for AngularJS</title> <link rel="stylesheet" type="text/css" href="../../jqwidgets/styles/jqx.base.css" /> <script type="text/javascript" src="../../scripts/angular.min.js"></script> <script type="text/javascript" src="../../scripts/jquery-1.11.1.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdraw.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxchart.core.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxangular.js"></script> <script type="text/javascript" src="../../scripts/demos.js"></script> <script type="text/javascript"> var demoApp = angular.module("demoApp", ["jqwidgets"]); demoApp.controller("demoController", demoController); function demoController() { var dm = this; dm.dataAdapter = new $.jqx.dataAdapter({ datatype: "csv", datafields: [ { name: 'Country' }, { name: 'GDP' }, { name: 'DebtPercent' }, { name: 'Debt' } ], url: '../sampledata/gdp_dept_2010.txt' }, { async: false, autoBind: true, loadError: function (xhr, status, error) { alert('Error loading'); } }); // prepare jqxChart settings dm.chartSettings = { title: "Economic comparison", description: "GDP and Debt in 2010", showLegend: true, enableAnimations: true, padding: { left: 5, top: 5, right: 50, bottom: 5 }, titlePadding: { left: 90, top: 0, right: 0, bottom: 10 }, source: dm.dataAdapter, xAxis: { dataField: 'Country', showGridLines: true }, colorScheme: 'scheme01', seriesGroups: [ { type: 'column', columnsGapPercent: 50, valueAxis: { unitInterval: 5000, displayValueAxis: true, description: 'GDP & Debt per Capita($)' }, series: [ { dataField: 'GDP', displayText: 'GDP per Capita' }, { dataField: 'Debt', displayText: 'Debt per Capita' } ] }, { type: 'line', valueAxis: { unitInterval: 10, displayValueAxis: false, description: 'Debt (% of GDP)' }, series: [ { dataField: 'DebtPercent', displayText: 'Debt (% of GDP)' } ] } ] }; dm.setLineChartType = function() { dm.chartSettings.seriesGroups[0].type = 'line'; } }; </script> </head> <body> <div data-ng-controller="demoController as dm"> <jqx-chart jqx-settings="dm.chartSettings" jqx-watch="dm.chartSettings.seriesGroups" style="width: 850px; height: 500px;"></jqx-chart> <br /> <jqx-button jqx-on-click="dm.setLineChartType()">Set Line Chart Type</jqx-button> </div> </body> </html>
http://www.jqwidgets.com/That worked thank you very much. I appreciate the help.
