jQuery UI Widgets Forums Angular JQX Grid filtering issue
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 4 years ago.
  • JQX Grid filtering issue #115221
    jos3hd17
    Hi all, i’m trying to implement the “Excel like filtering” on my table, and if I filter in a column and then move to a different column, I will see all the document items selected, do I have chance to change this behavior?
    JQX Grid filtering issue #115270
    Hello jos3hd17,
    I would like to ask you for more details.
    If I understand you right it will be better to use the createfilterwidget callback to customize the logic because by default there is no such built-in option.
    Please, take a look at this example below that you could try as an alternative:
    https://jseditor.io/?key=jqxgrid-cascading-checkedlist-filter
    It is created with a native JavaScript approach but if you like it I could help you to re-create it for Angular.
    https://www.jqwidgets.com
