jQuery UI Widgets › Forums › Chart › jqx chart using jqx data adapter with paramteres
This topic contains 1 reply, has 2 voices, and was last updated by Hristo 9 years, 5 months ago.
Hi guys,
I want to create jqx chart depending on selected values from two jqx drop down lists.
It works with this code. But after I choose different value from one of the drop down lists it takes a lot of time before even GET is send to the server for the data and it says that script is unresponsive jqxChart.js. After some time it will render chart. I am wondering if I am using the correct way. My data have 8760 records and I am ploting line chart.var srcYears = ["2010","2012","2014"]; $("#ddlYears").jqxDropDownList({ source: srcYears, selectedIndex: 0, theme: 'fresh', width: '100px' }); var srcTech = ["Solar","Wind","Demand"]; $("#ddlTech").jqxDropDownList({ source: srcTech, selectedIndex: 0, theme: 'fresh', width: '100px' }); $("#btnChartGenerate").jqxButton({width: '200',theme: 'fresh'}); $('#btnChartGenerate').on('click', function () { var year = $("#ddlYears").jqxDropDownList('getSelectedItem').value; var tech = $("#ddlTech").jqxDropDownList('getSelectedItem').value; var myURL2 ='phase2/HourlyAnalysis_data.php?e=3&year='+year+'&tech='+tech; var srcChart = { url: myURL2, root: 'data', datatype: 'json', cache: false, async: true, }; var daChart = new $.jqx.dataAdapter(srcChart); var settings = { title: "Input data", description: "", padding: { left: 5, top: 5, right: 5, bottom: 5 }, titlePadding: { left: 0, top: 0, right: 0, bottom: 10 }, source: daChart, enableAnimations: true, categoryAxis: { dataField: 'hour', description: '', showGridLines: true, showTickMarks: true }, seriesGroups: [{ type: 'line', valueAxis: { description: 'Value', logarithmicScale: true, logarithmicScaleBase: 2, unitInterval: 1, tickMarksInterval: 1, gridLinesInterval: 1, formatSettings: { decimalPlaces: 3 }, horizontalTextAlignment: 'right' }, series: [{ dataField: 'value', displayText: 'Hour Value' }] }] } $('#jqxChart').jqxChart(settings); });
I am creating everything in on click event of jqx button. Is there some other way??
this is sample of my data if you choose year =2010 and tech = Solar and I have 8760 values for H, I will show only some of them{"data":[ { "hour": "H1", "value": 36075.921875 }, { "hour": "H2", "value": 35573.53125 }, { "hour": "H3", "value": 35406.421875 }, { "hour": "H4", "value": 35267.37890625 }, { "hour": "H5", "value": 35266.16796875 }, { "hour": "H6", "value": 35776.8046875 ......
Thanks a lot
Hello atomic,
You could set url address and after that call
dataBind()
method from jqxDataAdapter, and after thisupdate()
method of the Chart.
Please take a look this example: http://jsfiddle.net/txhi/gam1sypw/ (analogically like localdata in the example)
This demo in ‘Java Integration’ section would be helpful:
http://jspexamples.jqwidgets.com/examples/chart.htm?arcticBest Regards,
Hristo HristovjQWidgets team
