jQuery UI Widgets Forums Angular JQX Angular Grid Not working with auto row height And fix grid Height
This topic contains 2 replies, has 3 voices, and was last updated by  admin 7 years ago.
  • faizan
    Angular JQX Grid is not working with dynamic loaded component in row.
    Below mentioned URL of JQX widget (Dynamic Components with Angular and jQWidgets WITH GRID) not working.
    https://www.jqwidgets.com/angular-components-documentation/documentation/angular-dynamic-components/index.htm?search=
    When Initially loaded it works fine
    screenshot
    NOT WORKING : After scroll it get distorted the row height it start increasing with scroll.
    screenshot-1
    screenshot-2
    Configuration
    <jqxGrid #grid [autorowheight]=”true” [width]=”‘100%'” [pageable]=”true” [height]=”300″ [theme]=”‘metro'” [columns]=columns>
    Martin
    Hello faizan,
    Thank you for your feedback!
    Yes, this is a known issue and we are currently working to fix it.
    Martin
    admin
    Hi faizan,
    The issue here, requires extension of the demo code and especially the app.component.ts.
    The solution is:
    import { jqxDomService } from './jqwidgets-dom.service';
    import { Component, OnInit, EventEmitter } from '@angular/core';
    import { jqxButtonComponent } from 'jqwidgets-scripts/jqwidgets-ts/angular_jqxbuttons';
    export class Hero {
    @Component({
      selector: 'app-root',
      template:
    Angular Dynamic Component Loader
    Id Name {{hero.id}} {{hero.name}}
    {{clickMessage}}
    export class AppComponent {
    HEROES: Hero[] = [
    { id: 11, name: ‘Mr. Nice’ },
    { id: 12, name: ‘Narco’ },
    { id: 13, name: ‘Bombasto’ },
    { id: 14, name: ‘Celeritas’ },
    { id: 15, name: ‘Magneta’ },
    { id: 16, name: ‘RubberMan’ },
    { id: 17, name: ‘Dynama’ },
    { id: 18, name: ‘Dr IQ’ },
    { id: 19, name: ‘Magma’ },
    { id: 20, name: ‘Tornado’ }
    clickMessage = ”;
    onClickMe(event) {
    this.clickMessage = ‘You are my hero ‘ + event.target.textContent;
    constructor(private jqxDomService: jqxDomService) {
    ngOnInit() {
    columns: any[] =
    text: ‘Id’, width: 110, datafield: ‘Id’,
    createwidget: (row: number, column: any, value: string, htmlElement: HTMLElement): void => {
    const that = this;
    let container = document.createElement(‘div’);
    htmlElement.style.overflow= “hidden”;
    htmlElement.style.maxHeight = “30px”;
    htmlElement.appendChild(container);
    let result = this.jqxDomService.loadComponent(jqxButtonComponent, container);
    (result.componentRef.instance).autoCreate = false;
    result.componentRef.instance).onClick.subscribe((clickEvent, value) => {
    that.onClickMe(clickEvent);
    result.componentRef.instance).createComponent({value: value, height:30, width: 100});
    initwidget: (row: number, column: any, value: any, htmlElement: HTMLElement): void => { }
    { text: ‘Name’, datafield: ‘Name’ }
    Peter
