jQuery UI Widgets › Forums › Plugins › AngularJS › jQWidgets-AngularJS issue using ng-include
This topic contains 3 replies, has 2 voices, and was last updated by Peter Stoev 9 years, 2 months ago.
The problem occurs while i use ng-include to seperate out the HTML portion in the index page. The screen goes blank.
(The same code works fine when the HTML ((testForm.html) portion is part of index page (index.html)).I have pasted the code below.
KeshavanauthApp.js
(function () { angular.module("authApp", ["jqwidgets", "firebase"]); }())
authController.js
(function () { authController = function ($scope, $firebaseAuth, service, validate) { $scope.authData = null; $scope.error = null; $scope.email = null; $scope.password = null; var ref = new Firebase("https://flickering-torch-6953.firebaseio.com"); $scope.authObj = $firebaseAuth(ref); $scope.authView = "testForm.html"; $scope.validatorSettings = { hintType: 'label', animationDuration: 0, rules: [ { input: '#passwordInput', message: 'Password is required!', action: 'keyup, blur', rule: 'required' }, { input: '#passwordInput', message: 'Your password must be between 4 and 12 characters!', action: 'keyup, blur', rule: 'length=4,12' }, { input: '#emailInput', message: 'E-mail is required!', action: 'keyup, blur', rule: 'required' }, { input: '#emailInput', message: 'Invalid e-mail!', action: 'keyup', rule: 'email' } ] } $scope.validate = function () { $scope.validatorSettings.$apply('validate'); } $scope.validate(); $scope.login = function () { login($scope, ref); }; } angular.module('authApp').controller('authController', ['$scope', '$firebaseAuth', authController]); }())
index.html
<!DOCTYPE html> <html ng-app="authApp"> <head> <title id="Description">jqxInput directive for AngularJS</title> <link rel="stylesheet" type="text/css" href="/angularjs/jQWidgets/jqwidgets/styles/jqx.base.css" /> <script type="text/javascript" src="/angularjs/jQWidgets/scripts/jquery-1.11.1.min.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/angular.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxangular.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxinput.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxpasswordinput.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/jqxvalidator.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/scripts/demos.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/authApp.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/authController.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/register.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/logIn.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/logOut.js"></script> <script src="https://cdn.firebase.com/js/client/2.2.4/firebase.js"></script> <script type="text/javascript" src="/angularjs/jQWidgets/jqwidgets/globalization/globalize.js"></script> <script src="https://cdn.firebase.com/libs/angularfire/1.1.3/angularfire.min.js"></script> </head> <body> <div ng-controller = "authController"> <div ng-include="authView"></div> </div> </body> </html>
testForm.html
<div ng-app="authApp"> <jqx-input ng-model="email" jqx-width="200" jqx-height="25" id="emailInput" placeholder="'Enter your eMail Id'"> </jqx-input>{{email}} <br /> <br /> <jqx-password-input ng-model="password" jqx-width="200" jqx-height="25" type="password" placeholder="'Enter your Password'" id="passwordInput"></jqx-password-input> <br /> <jqx-toggle-button jqx-settings="settings" ng-click="register()">register</jqx-toggle-button> <jqx-toggle-button jqx-settings="settings" ng-click="logIn()">logIn</jqx-toggle-button> <jqx-toggle-button jqx-settings="settings" ng-click="logOut()">logOut</jqx-toggle-button> </div> <div ng-if="error" <strong> error !! {{error}}</strong>></div> <div ng-if="authData" <strong> success !! UID : {{ authData.uid }}</strong>></div>
login.html
(function (){ logIn = function ($scope,ref) { ref.authWithPassword ({ "email": $scope.email, "password": $scope.password }, function (error, authData) { if (error) { alert(error); console.log("Login Failed ! ", error); } else { $scope.authData = authData; alert("Authenticated successfully - UID : " + authData.uid); console.log("Authenticated successfully with payload:", authData); } }); } angular.module('authApp').service('service', logIn); }());
The path to external HTML file (testForm.html) is also CORRECT.
KeshavanHi,
jQWidgets ver 4.0.
I am copying Google chrome console error,
angular.js:12477 TypeError: $scope.validatorSettings.$apply is not a function at Scope.$scope.validate (authController.js:41) at new authController (authController.js:43) at Object.invoke (angular.js:4478) at extend.instance (angular.js:9136) at nodeLinkFn (angular.js:8248) at compositeLinkFn (angular.js:7680) at compositeLinkFn (angular.js:7684) at compositeLinkFn (angular.js:7684) at publicLinkFn (angular.js:7555) at angular.js:1662
KeshavanHi Keshavan,
The issue here is that you think that $apply should be defined, but it should not be, because validatorSettings is a custom object. I am sorry, but this is not a jQWidgets issue.
