jQuery UI Widgets Forums Grid Issues applying more than one filter
This topic contains 7 replies, has 2 voices, and was last updated by  naatha 12 years, 2 months ago.
  • Issues applying more than one filter #18480
    naatha
    I have drop down list which contains different filters, filter1, filter2 …
    And also i set
    showfilterrow: true
    filterable: true
    When i select filter1 from the drop down list, i get 160 records out of 1500 records. Now i want to search for some one whose first name start with P with in the 160 records.
    When i type P in the filter row (text box under the First Name column header), it over write the existing filter1 and use all the 1500 records instead of 160 records.
    What i want is to keep the filter selected from the drop down list while applying other filter in the filter row.
    Could you please help me to achieve this?
    Thank you
    Issues applying more than one filter #18492
    Hello naatha,
    Please update to the latest version of jQWidgets (2.8) and share if you still experience the reported issue after that.
    Issues applying more than one filter #18503
    naatha
    Hi Dimitar,
    I have updated to latest version.
    I am using the following function filter function:
    var addfilter = function (columnname) {
    $(“#jqxgrid”).jqxGrid(‘clearfilters’);
    if (columnname == ”) return;
    var filter_or_operator = 1;
    var filtervalue = ”;
    var filtercondition = ‘not_empty’;
    var filter1 = filtergroup.createfilter(‘stringfilter’, filtervalue, filtercondition);
    $(“#jqxgrid”).jqxGrid(‘addfilter’, columnname, filtergroup);
    $(“#jqxgrid”).jqxGrid(‘applyfilters’);
    when the column type is string, int works fine. But failed for date type.
    Used to work fine with version 2.7.
    Do i need to change anything?
    Issues applying more than one filter #18504
    Hi naatha,
    Could you please provide us with a larger code sample, including your source definition and your grid initialization? Remember to format your code as explained in the forum topic Code Formatting.
    Issues applying more than one filter #18505
    naatha
    Hi Dimitar,
    I have just found out –
    when i set showfilterrow: false, it works.
    when i set showfilterrow: true, get the following error message:
    Unhandled exception at line 7, column 14438 in http://localhost:64535/jqwidgets/jqxgrid.filter.js
    0x800a138f – JavaScript runtime error: Unable to get property ‘filtervalue’ of undefined or null reference
    thanks
    Issues applying more than one filter #18568
    naatha
    Hi Dimitar,
    Here is the code sample.
    When i select the Filter1 – Date, i am getting the error with v 2.8 (worked fine with v 2.7)
    My real problem with v 2.7 is:
    Say i have 10 empty values in Ship Date column out of 100 rows.
    When i select the Filter1-Date, the grid only displays 90 rows where the date is non-empty.
    After that when i use the filterrow to search some one, it overwrite the existing filter.
    How can i avoid this?
    Thanks in advance.
    <title id='Description'></title>
    <link rel="stylesheet" href="jqwidgets/styles/jqx.base.css" type="text/css" />
    <link rel="stylesheet" href="jqwidgets/styles/jqx.summer.css" type="text/css" />
    <script type="text/javascript" src="scripts/jquery-1.8.3.min.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxbuttons.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxscrollbar.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxmenu.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxgrid.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxgrid.sort.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxgrid.filter.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxgrid.selection.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxgrid.pager.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxgrid.columnsresize.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxdata.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxpanel.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxcheckbox.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxlistbox.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxdropdownlist.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxgrid.columnsreorder.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxnumberinput.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxcalendar.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxdatetimeinput.js"></script>
    <script type="text/javascript" src="jqwidgets/globalization/jquery.global.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxcombobox.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxradiobutton.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxgrid.storage.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxwindow.js"></script>
    <script type="text/javascript" src="Scripts/generatedata.js"></script>
    var theme = "summer";
    var ddlsource = [
    "Select a filter ...",
    "Filter1 - Date",
    "Filter2 - First Name",
    "Filter3 - Quantity",
    $("#jqxWidget1").jqxDropDownList({ source: ddlsource, selectedIndex: 0, width: '200', height: '25', theme: theme, openDelay: 500, closeDelay: 750, animationType: 'none', autoDropDownHeight: true });
    $('#jqxWidget1').on('select', function (event) {
    var args = event.args;
    if (args) {
    var index = args.index;
    if (index == 0) {
    addfilter('');
    else if (index == 1) {
    addfilter('date');
    $("#jqxgrid").jqxGrid('sortby', 'date', 'desc');
    else if (index == 2) {
    addfilter('firstname');
    $("#jqxgrid").jqxGrid('sortby', 'firstname', 'desc');
    else if (index == 3) {
    addfilter('quantity');
    $("#jqxgrid").jqxGrid('sortby', 'quantity', 'desc');
    $("#jqxgrid").jqxGrid('clearfilters');
    if (columnname == '') return;
    var filtervalue = '';
    var filtercondition = 'not_empty';
    var filter1 = filtergroup.createfilter('stringfilter', filtervalue, filtercondition);
    $("#jqxgrid").jqxGrid('addfilter', columnname, filtergroup);
    $("#jqxgrid").jqxGrid('applyfilters');
    var data = generatedata(100);
    localdata: data,
    datatype: "array",
    cache: false,
    datafields:
    { name: 'id', type: 'number' },
    { name: 'date', type: 'date', format: 'dd/MM/yyyy' },
    { name: 'price', type: 'number' }
    // initialize jqxGrid
    width: '1000',
    selectionmode: 'singlerow',
    sorttogglestates: 2,
    altrows: true,
    autoshowfiltericon: true,
    showsortmenuitems: false,
    columnsreorder: false,
    pagesizeoptions: ['5', '10', '15', '20', '25'],
    enabletooltips: true,
    showstatusbar: true,
    { text: 'ID', datafield: 'id', width: 50, cellsalign: 'center', align: 'center' },
    { text: 'First Name', datafield: 'firstname', width: 150, cellsalign: 'center', align: 'center', filtercondition: 'starts_with' },
    { text: 'Last Name', datafield: 'lastname', width: 150, cellsalign: 'center', align: 'center', filtercondition: 'starts_with' },
    { text: 'Product', datafield: 'productname', width: 200, cellsalign: 'center', align: 'center', filtercondition: 'starts_with' },
    { text: 'Available', datafield: 'available', columntype: 'checkbox', width: 100, cellsalign: 'center', align: 'center' },
    { text: 'Ship Date', datafield: 'date', width: 150, cellsalign: 'center', align: 'center', cellsformat: 'yyyy-MM-dd', filtertype: 'date' },
    { text: 'Quantity', datafield: 'quantity', width: 100, cellsalign: 'center', align: 'center' },
    { text: 'Price', datafield: 'price', width: 100, cellsalign: 'center', align: 'center', cellsformat: 'c2' }
    <div id='jqxWidget1' style="float: left; margin-left: 75px; margin-right: 25px; margin-top: 30px; margin-bottom: 30px">
    <div id='jqxWidget' style="margin-left: 75px; margin-bottom: 30px; margin-top: 30px">
    <div id="jqxgrid"></div>
    Issues applying more than one filter #18591
    Hi naatha,
    Here is a working example, using version 2.8:
    <link rel="stylesheet" href="../../jqwidgets/styles/jqx.summer.css" type="text/css" />
    <script type="text/javascript" src="../../scripts/jquery-1.9.1.min.js"></script>
    <script type="text/javascript" src="../../../../jqwidgets/jqxcore.js"></script>
    <script type="text/javascript" src="../../jqwidgets/jqxgrid.columnsreorder.js"></script>
    <script type="text/javascript" src="../../jqwidgets/jqxnumberinput.js"></script>
    <script type="text/javascript" src="../../jqwidgets/globalization/jquery.global.js"></script>
    <script type="text/javascript" src="../../jqwidgets/jqxradiobutton.js"></script>
    <script type="text/javascript" src="../../jqwidgets/jqxgrid.storage.js"></script>
    <script type="text/javascript" src="../../../demos/jqxgrid/generatedata.js"></script>
    var ddlsource = [
    "Filter1 - Date",
    if (args) {
    if (index == 0) {
    addfilter('');
    addfilter('date');
    if (columnname == '') {
    return;
    } else if (columnname == "date") {
    var d1 = new Date(2013, 06, 01);
    var filtervalue1 = d1;
    var filtercondition1 = 'less_than';
    var filter1 = filtergroup.createfilter('datefilter', filtervalue1, filtercondition1);
    var d2 = new Date(2013, 01, 01);
    var filtervalue2 = d2;
    var filtercondition2 = 'greater_than';
    var filter2 = filtergroup.createfilter('datefilter', filtervalue2, filtercondition2);
    filtergroup.addfilter(filter_or_operator, filter2);
    } else if (columnname == "firstname" || columnname == "quantity") {
    localdata: data,
    datatype: "array",
    cache: false,
    datafields:
    width: '1000',
    altrows: true,
    { text: 'Ship Date', datafield: 'date', width: 150, cellsalign: 'center', align: 'center', cellsformat: 'yyyy-MM-dd' },
    <div id="jqxgrid">
    Issues applying more than one filter #18598
    naatha
    Thanks Dimitar and it works fine.
