jQuery UI Widgets Forums Grid Issue with setcellvalue
This topic contains 5 replies, has 2 voices, and was last updated by  Dimitar 11 years, 5 months ago.
  • Issue with setcellvalue #46686
    ssp
    On editing a cell or just clicking on any cell of the grid, I want to update another particular cell in the same row to zero.
    Issue: I am not able to update the another cell using setcellvalue!
    plz suggest whether is this possible??
    var gridName = "#"+location+"Grid";
        	var editedIndex;
    			var value;
      		$(gridName).jqxGrid({
      			width: gridWidth,
      			autoheight : true,
     			source : dataAdapter,
     			theme : 'theme',
     			editable : true,
     			rowsheight:21,
     			showstatusbar : true,
     			showfiltercolumnbackground: true,
     			showfilterrow: true,
                showaggregates : true,
                columnsresize:true,
     			selectionmode : 'multiplecellsadvanced',
     			columns :gridColumns
      		$("#"+location+"Grid").bind('cellendedit', function (event) {
    $("#"+location+"Grid").jqxGrid('setcellvalue', rowIndex, 'strSurplusOrDeficit', 0);
    Thanks & Regards,
    Sandhya
    Issue with setcellvalue #46689
    Hello Sandhya,
    In your example, rowIndex is undefined, that is why setcellvalue does not work. Our suggestion is to use the column cellbeginedit callback function, as in the following example, based on the demo Default Functionality:
                var theme = getDemoTheme();
                var url = "../sampledata/products.xml";
                    datatype: "xml",
                        { name: 'ProductName', type: 'string' },
                        { name: 'QuantityPerUnit', type: 'int' },
                        { name: 'UnitPrice', type: 'float' },
                        { name: 'UnitsInStock', type: 'float' },
                        { name: 'Discontinued', type: 'bool' }
                    root: "Products",
                    record: "Product",
                    url: url
                    if (value < 20) {
                        return '<span style="margin: 4px; float: ' + columnproperties.cellsalign + '; color: #ff0000;">' + value + '</span>';
                    else {
                // sets the "Quantity per Unit" cell on the same row to 0
                var updateToZero = function (row, datafield, columntype) {
                    $("#jqxgrid").jqxGrid('setcellvalue', row, "QuantityPerUnit", 0);
                // initialize jqxGrid
                    width: 670,
                    altrows: true,
                    enabletooltips: true,
                      { text: 'Product Name', columngroup: 'ProductDetails', datafield: 'ProductName', width: 250, cellbeginedit: updateToZero },
                      { text: 'Quantity per Unit', columngroup: 'ProductDetails', datafield: 'QuantityPerUnit', cellsalign: 'right', align: 'right', width: 120 },
                      { text: 'Unit Price', columngroup: 'ProductDetails', datafield: 'UnitPrice', align: 'right', cellsalign: 'right', cellsformat: 'c2', width: 100, cellbeginedit: updateToZero },
                      { text: 'Units In Stock', datafield: 'UnitsInStock', cellsalign: 'right', cellsrenderer: cellsrenderer, width: 100, cellbeginedit: updateToZero },
                      { text: 'Discontinued', columntype: 'checkbox', datafield: 'Discontinued', cellbeginedit: updateToZero }
                    columngroups: [
                        { text: 'Product Details', align: 'center', name: 'ProductDetails' }
            <div id="jqxgrid">
    Issue with setcellvalue #46712
    ssp
    Hi Dimitar,
    Sorry I had missed copying rowIndex lines in the above post,
    ‘setcellvalue’ doesn’t work for me even then,
      var args = event.args;
      			var columnDataField = args.datafield;
      			var rowIndex = args.rowindex;
    And in the demo default functionality link you have mentioned above, I cant find the updating of the “Quantity per Unit” cell on the same row to 0 on editing “Product Name” cell value??
    Thanks & Regards,
    Sandhya
    Issue with setcellvalue #46713
    Hi Sandhya,
    This functionality is found in the example code we provided you, not in the Default Functionality demo. Please try it out.
    Issue with setcellvalue #46770
    ssp
    Hi Dimitar,
    I am not able to set the cell value to zero on cellbeginevent using the example code you have provided above.
    Is it not possible to call setcellvalue inside cellbeginevent event like below?
    <strong>$("#"+location+"Grid").jqxGrid('setcellvalue', rowIndex, 'strSurplusOrDeficit', 0);</strong>
    Thanks & Regards,
    Sandhya
    Issue with setcellvalue #46773
    Hi Sandhya,
    The code we provided you works fine on our side. Do you experience any issues with it? Please make sure you are using the latest version of jQWidgets (3.0.4).
    Your approach also works, but changes the value to 0 after the cell has been edited. Here is an example:
                    datatype: "xml",
                    root: "Products",
                    record: "Product",
                    url: url
                    if (value < 20) {
                    else {
                    width: 670,
                    altrows: true,
                        { text: 'Product Name', columngroup: 'ProductDetails', datafield: 'ProductName', width: 250 },
                        { text: 'Unit Price', columngroup: 'ProductDetails', datafield: 'UnitPrice', align: 'right', cellsalign: 'right', cellsformat: 'c2', width: 100 },
                        { text: 'Units In Stock', datafield: 'UnitsInStock', cellsalign: 'right', cellsrenderer: cellsrenderer, width: 100 },
                        { text: 'Discontinued', columntype: 'checkbox', datafield: 'Discontinued' }
                    columngroups: [
                $("#jqxgrid").bind('cellendedit', function (event) {
                    if (columnDataField != "QuantityPerUnit") {
                        $("#jqxgrid").jqxGrid('setcellvalue', rowIndex, 'QuantityPerUnit', 0);
            <div id="jqxgrid">
    The issue on your side may come from the use of the location variable in your grid’s id.
