jQuery UI Widgets › Forums › Grid › Issue with Resizing Grid & SelectedRow editmode
Tagged: angular grid, angular2 grid, bootstrap grid, javascript grid, jquery grid, jqwidgets grid, jqxgrid, typescript grid
This topic contains 1 reply, has 2 voices, and was last updated by Hristo 8 years, 6 months ago.
I’ve run into an issue in my application that I was able to replicate in the demo code provided with 4.1.2. I have a simple editable grid where the editmode is set to “SelectedRow” and the columns are resizable. If a user starts to edit a row, and without exiting edit mode, tries to resize the column, the values entered in all fields of the row revert back to the previous value.
Here’s the code (from the demo):
<!DOCTYPE html> <html lang="en"> <head> <title id='Description'>In this example, the columns resizing feature is enabled. The resizing of the 'Total' column is disabled by setting the 'resizable' property to false.</title> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.11.1.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.columnsresize.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.edit.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdropdownlist.js"></script> <script type="text/javascript" src="generatedata.js"></script> <script type="text/javascript" src="../../scripts/demos.js"></script> <script type="text/javascript"> $(document).ready(function () { // prepare the data var data = generatedata(); var source = { localdata: data, datafields: [ { name: 'firstname', type: 'string' }, { name: 'lastname', type: 'string' }, { name: 'productname', type: 'string' }, { name: 'available', type: 'bool' }, { name: 'quantity', type: 'number' }, { name: 'price', type: 'number' }, { name: 'total', type: 'number' } ], datatype: "array" }; var dataAdapter = new $.jqx.dataAdapter(source); $("#jqxgrid").jqxGrid( { width: 850, source: dataAdapter, columnsresize: true, selectionmode: 'singlerow', editmode: 'selectedrow', editable: true, columns: [ { text: 'First Name', datafield: 'firstname', width: 100 }, { text: 'Last Name', datafield: 'lastname', width: 100 }, { text: 'Product', datafield: 'productname', width: 180 }, { text: 'Quantity', datafield: 'quantity', width: 80, cellsalign: 'right' }, { text: 'Unit Price', datafield: 'price', width: 90, cellsalign: 'right', cellsformat: 'c2' }, { text: 'Total', datafield: 'total', minwidth: 100, resizable: false, width: 'auto', cellsalign: 'right', cellsformat: 'c2' } ] }); // trigger the column resized event. $("#jqxgrid").on('columnresized', function (event) { var column = event.args.columntext; var newwidth = event.args.newwidth var oldwidth = event.args.oldwidth; $("#eventlog").text("Column: " + column + ", " + "New Width: " + newwidth + ", Old Width: " + oldwidth); }); }); </script> </head> <body class='default'> <div id='jqxWidget'> <div id="jqxgrid"></div> <div style="margin-top: 30px;" id="eventlog"></div> </div> </body> </html>
Is this a known issue or is the functionality expected? Is there a workaround that can be used?
Thanks!
Hello lastrom,
In this case, the Grid stay in the edit mode.
You could useendcelledit
method when the “columnresized” event is triggered. Thus will set the new value.Best Regards,
Hristo HristovjQWidgets team
