jQuery UI Widgets Forums Grid Issue with Multiple grids on same page
This topic contains 2 replies, has 3 voices, and was last updated by  Akshatha Raju 11 years, 10 months ago.
  • Hi,
    I’m facing an issue with “Select Rows” option on pager while using multiple grids on same page.
    The “select rows” option is enabled only for the last instance of grid in which the grids are initialized.
    Hi dphansekar,
    Thank you for the bug report.
    I tested the reported issue and I confirm that there’s an issue regarding the ‘Select Rows’ DropDown. It will be resolved in the upcoming release which is scheduled for 03/09/2012. As a work around, I suggest you to take a look at this topic: jquery-grid-paging.htm. The help topic describes how to customize the Grid Pager’s rendering and display the page numbers as links.
    Akshatha Raju
    I have to develop four nested grids using spring MVC, for which I am referring to your sample code “server_side_grid__with_nested_grids” in phpdemos and am able to get two nested grids and now trying to for the next level nested grid by modifying the same code…
    please suggest me the method to link to the third nested grid using your sample code!!
    Thanks & Regards,
    Sandhya S P
