jQuery UI Widgets › Forums › Dialogs and Notifications › Window › Issue with Modal Window
This topic contains 1 reply, has 2 voices, and was last updated by Peter Stoev 12 years, 8 months ago.
AuthorIssue with Modal Window Posts
Hi there
I have a modal popup window I’d like to show on a button-click. It seems that there is an issue when a gauge widget is in that window.
I need the window’s “autoOpen” property to be set to false. If set to true it works…
Test code:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml"><head> <meta http-equiv="content-type" content="text/html; charset=utf-8" /> <link rel="stylesheet" href="jqwidgets/styles/jqx.base.css" type="text/css" /> <link rel="stylesheet" href="jqwidgets/styles/jqx.classic.css" type="text/css" /> <script type="text/javascript" src="scripts/jquery-1.7.2.min.js"></script> <script type="text/javascript" src="jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="jqwidgets/jqxbuttons.js"></script> <script type='text/javascript' src="jqwidgets/jqxwindow.js"></script> <script type='text/javascript' src="jqwidgets/jqxchart.js"></script> <script type="text/javascript" src="jqwidgets/jqxgauge.js"></script> </head><body id="bodyContainer"> <script type="text/javascript"> $(document).ready(function () { $('#popupButton').jqxButton({ }); $('#voiceWindow').jqxWindow({ width: 630, height: 470, resizable: false, showCloseButton: false, isModal: true, autoOpen: false }); labels = { position: 'far', interval: 15, formatValue: function (value, position) { return value + 's'; }}; $('#voiceGauge').jqxLinearGauge({ orientation: 'horizontal', height: '60px', width: '250px', labels: labels, min: 0, max: 15, colorScheme: 'scheme05', ticksPosition: 'far', background: { style: { stroke: '#cccccc', fill: '#cccccc'}, visible: true, backgroundType: 'rectangle' }, ticksMajor: { size: '7px', interval: 1, style: { stroke: '#898989'}, visible: true }, ticksMinor: { size: '7px', interval: 1, style: { stroke: '#898989'}, visible: false }, ranges: [ { startValue: 0, endValue: 7, style: { fill: '#FF4800', stroke: '#FF4800'} }, { startValue: 7, endValue: 9, style: { fill: '#FFA200', stroke: '#FFA200'} }, { startValue: 9, endValue: 11, style: { fill: '#FFF157', stroke: '#FFF157'} }, { startValue: 11, endValue: 13, style: { fill: '#FFA200', stroke: '#FFA200'} }, { startValue: 13, endValue: 15, style: { fill: '#FF4800', stroke: '#FF4800'} }] }); $('#voiceGauge').jqxLinearGauge('value', 0); }); function showPopup() { $('#voiceWindow').jqxWindow('open'); }; </script> <div id='menuContainer'> <input type="button" value="Open Popup Window" id="popupButton" onclick="showPopup();" /> </div> <div id='voiceWindow'> <div>Popup Window</div> <div> <div id="voiceGauge"></div> </div> </div></body></html>
Thanks & cheers,
PeterHi Peter,
The Gauge should be initialized in a visible DIV tag. I.e if you initialize it in jqxWindow, make sure the window is already displayed. The initContent callback function is called when the window’s content should be initialized. You can use it to initialize the Gauge.
