jQuery UI Widgets Forums Grid Issue with jqxdata.export.js
This topic contains 12 replies, has 5 voices, and was last updated by  youyou 1 year, 8 months ago.
  • Issue with jqxdata.export.js #133561
    filipeds
    When I’m accessing my application locally with “localhost”, the export to excel feature works fine. However, when I access with my domain name (appname.domain.com) I get an error as soon I open the report page.
    The error is: Uncaught SyntaxError: Unexpected token ‘)’ (at jqxdata.export.js:8:30481).
    Has anyone else seen this?
    Thanks in advance.
    Issue with jqxdata.export.js #133566
    This behaviour is strange, may you share your code?
    Is the error there if you only import jqxdata.export.js, without initializing the grid?
    Svetoslav Borislavov
    https://www.jqwidgets.com/
    Issue with jqxdata.export.js #133574
    filipeds
    You can find below the rendered code.
    When the page loads, I have that posted error, and when I click on the export button I get another missing reference error: Uncaught jqxGrid: Missing reference to jqxdata.export.js!
    I’ll take a test without initializing the grid to reply to you.
    <form action="/Relatorios/ProducaoVendas" data-ajax="true" data-ajax-begin="InsuranceSelling.ModalMessage.showloading();" data-ajax-complete="InsuranceSellingForm.init(); InsuranceSelling.ModalMessage.hide(); InsuranceSellingForm.formAjaxOnComplete('Relatorios');" data-ajax-failure="SweetAlert.Error('Erro' , error);" data-ajax-method="POST" data-ajax-mode="replace" data-ajax-success="InsuranceSellingForm.formAjaxUpdateSuccessfull(data);" data-ajax-update="#resultRelatorio" id="formRelatorio" method="post">
    <div class="form-actions">
                        <div class="clearfix">
                            <button id="idButtonSearch" type="submit" class="btn blue" onclick="submitFormRelatorio();">Pesquisar  <i class="fa fa-table"></i></button>
    </form>
        <div id="resultRelatorio">
          <button id="idExportExcel" type="button" class="btn blue" onclick="exportExcel();">Exportar para Excel  <i class="fa fa-file-excel-o"></i></button>
        <script type="text/javascript" src="/Scripts/jqwidgets/jqxcore.js"></script>
        <script type="text/javascript" src="/Scripts/jqwidgets/jqxbuttons.js"></script>
        <script type="text/javascript" src="/Scripts/jqwidgets/jqxscrollbar.js"></script>
        <script type="text/javascript" src="/Scripts/jqwidgets/jqxmenu.js"></script>
        <script type="text/javascript" src="/Scripts/jqwidgets/jqxgrid.js"></script>
        <script type="text/javascript" src="/Scripts/jqwidgets/jqxdata.export.js"></script>
        <script type="text/javascript" src="/Scripts/jqwidgets/jqxgrid.selection.js"></script>
        <script type="text/javascript" src="/Scripts/jqwidgets/jqxgrid.columnsresize.js"></script>
        <script type="text/javascript" src="/Scripts/jqwidgets/jqxdata.js"></script>
        <script type="text/javascript" src="/Scripts/jqwidgets/jqxgrid.export.js"></script>
        <script type="text/javascript" src="/Scripts/jqwidgets/jqxexport.js"></script>
        <script type="text/javascript" src="/Scripts/jqwidgets/jqxgrid.sort.js"></script>
        <script type="text/javascript" src="/Scripts/jqwidgets/jqxgrid.filter.js"></script>
        <script type="text/javascript" src="/Scripts/jqwidgets/jqxgrid.pager.js"></script>
        <script type="text/javascript" src="/Scripts/jqwidgets/jqxgrid.grouping.js"></script>
        <script type="text/javascript" src="/Scripts/jqwidgets/jqxgrid.aggregates.js"></script>
        <script type="text/javascript" src="/Scripts/jqwidgets/jqxlistbox.js"></script>
        <script type="text/javascript" src="/Scripts/jqwidgets/jqxdropdownlist.js"></script>
            submitFormRelatorio = function () {
                $("#report").attr('href', "/Relatorios/ExportToExcel?DataInicial=" + $("input[name='DataInicial']").val() + "&DataFinal=" + $("input[name='DataFinal']").val());
            exportExcel = function () {
                $("#table").jqxGrid('exportdata', 'xls', 'relatorio');
            $(":input").focusout(function () {
                $("#report").attr('href', "/Relatorios/ExportToExcel?DataInicial=" + $("input[name='DataInicial']").val() + "&DataFinal=" + $("input[name='DataFinal']").val() + "&EstadoId=" + $("select[name='EstadoId']").val() + "&TipoVendedor=" + $("select[name='TipoVendedor']").val());
    Issue with jqxdata.export.js #133576
    admin
    The jqxdata.export.js is added two times and this could be problematic.
    Issue with jqxdata.export.js #133592
    filipeds
    Hi Peter, sorry for the delay in reply.
    Even after removing the duplicated call and not initializing the grid the problem still happens. Just loading the script.
    And when I try to export, I get a “Missing reference”.
    DevTools Error
    A strange thing I noticed looking deeper into the error was the several occurrences of the “X” word in the JS, as you can see below.
    Xs 1
    Xs 2
    Issue with jqxdata.export.js #133594
    Could you try moving the import of jqxdata.export.js before jqxgrid.js.
    Also, will the problem still exist if you import jqx-all.js instead every component
    Issue with jqxdata.export.js #133595
    filipeds
    Hi Svetoslav,
    With jqxdata.export.js before jqxgrid.js does not worked. But using the jqx-all.js worked like a charm!
    Any clue why?
    Many thanks!
    Issue with jqxdata.export.js #133596
    Could you please, send us the project or a demo project with the problem?
    Issue with jqxdata.export.js #133601
    filipeds
    I will try to replicate the problem in a demo project and send you.
    Kind regards.
    Issue with jqxdata.export.js #133608
    Thank you, we are waiting for you!
    Issue with jqxdata.export.js #133702
    robf
    I have a question regarding programmatically turning ON/OFF the ability to resize columns.
    I initially set it to true and resizing is allowed. I use code from your API ref to turn it off
    $(‘#jqxGrid’).jqxGrid({ columnsresize: false});
    I check that the value has changed – $(‘#jqxGrid’).jqxGrid(‘columnsresize’); >> false
    However, I can still resize the columns. The code seemingly has no effect. Can you please tell me what I am doing wrong?
    Please see this fiddle:
    https://jsfiddle.net/rfossella/a45uret1/57/
    Thank you
    Robert
    Issue with jqxdata.export.js #133711
    Thank you for reporting the problem!
    I have opened an issue for it.
    Issue with jqxdata.export.js #133880
    youyou
    How to use jqxMenu to achieve the following effect:
    Two-level menu with one item per row:In this case, i want to display the second-level menu items vertically, with one item in each row.
    Three-level menu with horizontal sorting:In this case,i want to display the third-level items in a horizontal layout. This means that the items at the third level will be arranged side by side in a row, allowing for multiple items to be displayed in a single row.
