jQuery UI Widgets Forums Grid Issue with Group function of jxGrid
This topic contains 4 replies, has 2 voices, and was last updated by  Peter Stoev 12 years, 7 months ago.
  • Issue with Group function of jxGrid #11913
    giapdangle
    I’m using jxGrid (in 2.5.5 release). I want to use the group function of jxGrid. This is the code that I used to init the jxGrid:
    var retsource = {
    datatype: "array",
    { name: 'index' },
    { name: 'name' },
    { name: 'province' },
    { name: 'district' },
    { name: 'ward' }
    localdata: mapDevSummaryInfos
    // ReSharper disable InconsistentNaming
    var dataAdapter = new $.jqx.dataAdapter(retsource);
    // ReSharper restore InconsistentNaming
    $("#divGridResults").jqxGrid({
    editable: false,
    enablehover: false,
    selectionmode: 'singlerow',
    groupable: true,
    showgroupsheader: false,
    width: '100%',
    height: '100%',
    { text: 'Id', datafield: 'index', width: '10%' },
    { text: 'Tên thiết bị', datafield: 'name', width: '90%' },
    { text: 'Tỉnh/TP', datafield: 'province', width: '0%' },
    { text: 'Quận/Huyện', datafield: 'district', width: '0%' },
    { text: 'Phường/Xã', datafield: 'ward', width: '0%' }
    ready: function() {
    $("#divGridResults").jqxGrid('hidecolumn', 'province');
    $("#divGridResults").jqxGrid('hidecolumn', 'district');
    $("#divGridResults").jqxGrid('hidecolumn', 'ward');
    groups: ['province', 'district', 'ward']
    However, the result is not as I expected. The district field has not been grouped correctly:
    1. the lable of field district is not displayed
    http://imageshack.us/photo/my-images/203/grouperror.png
    2. there are 06 districts in the sample data, however, they have not been grouped
    http://imageshack.us/photo/my-images/831/grouperror2.png
    The language that I used in this sample is Vietnamese.
    Could you please help to give me your advises on this issue?
    Thanks and best regards,
    Giap
    Issue with Group function of jxGrid #11921
    Hi Giap,
    Could you provide a sample data so we can test your scenario?
    Issue with Group function of jxGrid #12021
    giapdangle
    You can check with the following data
    sample data
    Thanks and regards,
    Giap
    Issue with Group function of jxGrid #12091
    giapdangle
    Did you have a chance to test it?
    Giap
    Issue with Group function of jxGrid #12148
    Hi Giap,
    In the sample data, you use: disrict instead of disctrict.
    The following code:
              mapDevSummaryInfos = new Array();
    for (idx = 0; idx < mapDevLists.length; idx++) {
    var row = {};
    row['index'] = mapDevLists[idx][0];
    row['name'] = mapDevLists[idx][1];
    row['province'] = mapDevLists[idx][3];
    row['disrict'] = mapDevLists[idx][4];
    row['ward'] = mapDevLists[idx][5];
    mapDevSummaryInfos[idx] = row;
    should be:
    var row = {};
    row['district'] = mapDevLists[idx][4];
