jQuery UI Widgets Forums Grid Issue with GetRowData
This topic contains 1 reply, has 2 voices, and was last updated by  Martin 7 years, 1 month ago.
  • Issue with GetRowData #100896
    CXXXV
    I have the following code:
    					{ text: '', align: 'center',  datafield: 'Edit', columntype: 'button', width: 65,
    						cellsrenderer: function () {
    						 return "Edit";},
    						buttonclick: function (row) {
    						editrow = row;
    						var offset = $("#membergrid").offset();
    						$("#popupWindow").jqxWindow({ position: { x: parseInt(offset.left) + 60, y: parseInt(offset.top) + 60 } });
    	                    var dataRecord = $("#membergrid").jqxGrid('getrowdata', editrow);
    						member = dataRecord.MEMID;
    						memname = dataRecord.MEMBERNAME;
    About 50% of the time the value of ‘member’ is undefined. I have not been able to determine why. Any suggestions.
    Issue with GetRowData #100904
    Martin
    Hello CXXXV,
    I’ve tried reproducing this but did not succeed having only the code you’ve sent.
    Can you, please, provide a larger example or some kind of a demo where the issue can be seen?
    Thank you!
    Martin
