jQuery UI Widgets › Forums › Grid › Issue with createeditor and initeditor
This topic contains 4 replies, has 2 voices, and was last updated by diegopitt 10 years, 6 months ago.
I have an editor which is a dropdownlist. I want to enable and disable items based on a row field. The enabling and disabling is working. The problem is after editing and moving to another row, the item value is not binded correctly with the editor. I think the editor is treated as it was for the previous row. It doesn’t recognize the new enabled and disabled values even thou they show correctly. It treats a re-enabled item as it was disabled so the binding doesn’t work and binds with the closest item. Bellow my code:
var GridModel = function () { this.menuitems = ko.observableArray(controller.get('menuitems')); }; my = { viewModel: new GridModel() }; var menus_source = { localdata: controller.get('menus'), datafields: [ { name: 'id' }, { name: 'name' } ], } var menus_dataAdapter = new $.jqx.dataAdapter(menus_source); var categories_source = { localdata: controller.get('categories'), datafields: [ { name: 'id' }, { name: 'name' } ], } var categories_dataAdapter = new $.jqx.dataAdapter(categories_source, {autoBind: true,async: false}); var departments_source = { localdata: controller.get('departments'), datafields: [ { name: 'id' }, { name: 'name' } ], } var departments_dataAdapter = new $.jqx.dataAdapter(departments_source, {autoBind: true,async: false}); var units_source = { localdata: controller.get('units'), datafields: [ { name: 'id' }, { name: 'name' } ], } var units_dataAdapter = new $.jqx.dataAdapter(units_source, {autoBind: true,async: false}); var menuitems_source = { localdata: my.viewModel.menuitems, datatype: 'observablearray', datafields: [ { name: 'id' }, { name: 'item_id' }, { name: 'name' }, { name: 'menu_id' }, { name: 'department', value: 'department_id', values: { source: departments_dataAdapter.records, value: 'id', name: 'name' } }, { name: 'category', value: 'category_id', values: { source: categories_dataAdapter.records, value: 'id', name: 'name' } }, { name: 'unit_id' }, { name: 'unit', value: 'unit_id', values: { source: units_dataAdapter.records, value: 'id', name: 'name' } }, { name: 'price', type:'number'}, { name: 'department_id' }, { name: 'category_id'}, { name: 'count'} ], } $("#Menus_grid").jqxGrid({ pageable: true, theme: 'energyblue', editable: true, autorowheight : true, rowsheight : 50, pagesize: 10, autoshowloadelement: false, autoheight: true, editmode: 'click', altrows:true, sortable: true, width:'100%', showtoolbar: true, toolbarheight:35, rendertoolbar: function (toolbar) { var me = this; var container = $("<div style='margin: 0px;'></div>"); var input = $("<div style='float:left;font-weight:bold' id='field'/>"); var addButton = $("<button id='add' style='float: right;' type='button' class='btn btn-success'><span style='color:#e0e9f5' class='glyphicon glyphicon glyphicon-plus' aria-hidden='true'></span> Add items </button>"); container.append(input); container.append(addButton); toolbar.append(container); $("#add").on('click', function () { controller.send("isadding"); }); if (controller.adding){ $("#add").hide()} container.append(input); input.jqxDropDownList({animationType: 'slide', theme:'energyblue', source: menus_dataAdapter, displayMember: "name", valueMember: "id", selectedIndex: 0, height: '32px', width: '460px'}); input.bind('change', function (event) { if (controller.adding){ $("#jqxitems").jqxComboBox('clearSelection'); } var args = event.args; if (event.args){ var value = event.args.item.value; } menuitems_dataAdapter.dataBind(); }); }, columns: [ { text: '', datafield: 'Delete', editable: false, width:'7%', cellsrenderer: function (row) { addclass=''; if($("#Menus_grid").jqxGrid('getrowdata', row).count > 0){ addclass=' disabled'; } var datarow = $("#Menus_grid").jqxGrid('getrowdata', row); items_sold = ''; var itemlbl; if (datarow.count > 1){ itemlbl = ' items sold'; }else{ itemlbl = ' item sold'; } return "<div title='" + datarow.count + itemlbl + "' style='width:100%;' class='text-center'><button onclick='controller.send("deletemenuitem"," + datarow.id + "," + datarow.index + ");' id='delete' style='margin-top:12px;padding:4px' type='button' class='btn btn-default" + addclass + "'><span style='color:#d95551' class='glyphicon glyphicon-remove'></span></button></div>"; } }, { text: 'id', dataField: 'id', hidden:true}, { text: 'Item Name', editable: false, dataField: 'name', width:'45%'}, { text: 'Category', dataField: 'category_id', displayfield: 'category', columntype: 'dropdownlist', width:'17%', createeditor: function (row, column, editor) { editor.jqxDropDownList({ autoDropDownHeight: true, source: categories_dataAdapter, displayMember:"name", valueMember: 'id'}); } }, { text: 'Department', columntype: 'dropdownlist', displayfield: 'department', dataField: 'department_id', width:'13%', createeditor: function (row, column, editor) { editor.jqxDropDownList({ autoDropDownHeight: true, source: departments_dataAdapter, displayMember:"name", valueMember: 'id'}); } }, { text: 'Unit', editable: true, columntype: 'dropdownlist', displayfield: 'unit', dataField: 'unit_id', width:'10%', createeditor:function(row, column, editor){ editor.jqxDropDownList({ autoDropDownHeight: true, source: units_dataAdapter, displayMember:"name", valueMember: 'id'}); }, initeditor: function (row, cellvalue, editor) { var xitems = editor.jqxDropDownList('getItems'); $.each(xitems, function (i) { editor.jqxDropDownList('enableAt', i ); }); var datarow = $("#Menus_grid").jqxGrid('getrowdata', row); var used_Units = getUnitsinUse(datarow.item_id); for (var i = 0; i < used_Units.length; i++) { if(datarow.unit_id != used_Units[i]){ editor.jqxDropDownList('disableItem',used_Units[i]); } } } }, { text: 'Unit price', dataField: 'price', width:'8%', cellsformat: 'c2', columntype: 'numberinput'} ] }); $("#Menus_grid").bind('cellvaluechanged', function (event) { var data = $("#Menus_grid").jqxGrid("getrowdata", args.rowindex); var newvalue; if (args.datafield == 'price'){ newvalue = args.newvalue; }else{ newvalue = args.newvalue.value; } //controller.send("editviewmenu", newvalue, args.datafield, data.id, args.oldvalue); }); units_data = new Array(); menuitems_dataAdapter = new $.jqx.dataAdapter(menuitems_source, { beforeLoadComplete: function (records) { units_data = []; for (var i = 0; i < records.length; i++) { var items = records[i]; if (items.menu_id == $("#field").jqxDropDownList('val')){ items.index = i; items.id = items.id; items.item_id = items.item_id; items.name = items.name; items.department = items.department; items.category = items.category; items.unit = items.unit; items.menu_id = items.menu_id; items.unit_id = items.unit_id; items.price = items.price; items.department_id = items.department_id; items.category_id = items.category_id; units_data.push(items) } } return units_data; } }); getUnitsinUse = function(item_id){ UnitsinUse = new Array; for (var i = 0; i < units_data.length; i++) { var items = units_data[i]; if(item_id == items.item_id){ UnitsinUse.push(items.unit_id) } } return UnitsinUse; } $("#Menus_grid").jqxGrid({source: menuitems_dataAdapter}); ko.applyBindings(my.viewModel, document.getElementById('viewUnits_wraper'));
In the initeditor I have to loop all items and re-enable them all because when I edit some other row the items show the disabled ones from the previous editing.
Hi diegopitt,
You have one column editor. initeditor is called when you open it – each time. createeditor is called one – when it’s opened for first time.
http://www.jqwidgets.comThanks Peter, not sure what you mean by You have one column editor. I am aware when the createeditor and initeditor are called
Diego
Is there a way to reset the editor for the next row edit? All the items changes I make remain there…
