jQuery UI Widgets Forums Grid Issue with add row
This topic contains 5 replies, has 2 voices, and was last updated by  Peter Stoev 11 years, 5 months ago.
  • Issue with add row #47897
    priyam.basu
    So, I’m trying to add a new row to the grid, when the user starts writing something in the last blank row. But when I do that, the focus moves to the newly added row, and the user has to click on the previous row again, to start typing. How can I avoid this?
    handlekeyboardnavigation: function (event) {
    var row = $(‘#TableDefinitionGrid’).jqxGrid(‘selectedrowindex’);
    var datainformations = $(‘#TableDefinitionGrid’).jqxGrid(‘getdatainformation’);
    var rowscounts = datainformations.rowscount;
    if (row == rowscounts – 1) {
    var newTableFieldID = guid();
    var value = $(‘#TableDefinitionGrid’).jqxGrid(‘addrow’, newTableFieldID,{ ‘DisplayName’: ”, ‘InternalName’: ”, ‘Description’: ” });
    //return false;
    Issue with add row #47915
    Hi priyam.basu,
    Isn’t it better to add a new row after the editing is finished i.e in the “cellendedit” event handler or in the source object’s “updaterow” function.
    Issue with add row #47917
    priyam.basu
    How do I get the index of the selected cell? getselectedcell is returning null
    Thanks you
    Issue with add row #47923
    Hi priyam.basu,
    If “getselectedcell” returns null, then there is no selected cell or you do not use any of the available cell selection modes. If that is so, then use the “getselectedrowindex” method.
    Issue with add row #47928
    priyam.basu
    Is there any way that I can check when the cursor is in the last cell of the last row?
    Thanks!
    Issue with add row #47932
    Hi priyam.basu,
    No, there’s no API for checking that.
