This topic contains 5 replies, has 2 voices, and was last updated by  Peter Stoev 11 years, 9 months ago.
  • Issue in Validator #26184
    gokul
    Hai There,
    I have some issue when using Validator control. Assume that I have a registration page, like http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxvalidator/index.htm?(web)#demos/jqxvalidator/defaultfunctionality.htm
    If I click submit button with enter those values, validator will give the tooltip to show the error message.
    This is OK. but if have more number of control its giving somewhat bad look. So is there any way to remove (or like as optional) those tooltip  and make the control border as red color.
    This somewhat feel good.
    Can you please give me a suggestion to achieve this.?
    Thanks, – Gokul.
    Issue in Validator #26188
    Hi Gokul,
    You can see the Error Labels demo. It works with Labels, not with Tooltips so if you don’t like the tooltips, this could be better for you.
    Issue in Validator #27230
    gokul
    Hai Peter,
    Thanks for your prompt reply.
    Just now I check the Error Label demo (http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxvalidator/index.htm#demos/jqxvalidator/validation-label.htm)
    This demo is not working, I am not see any difference after click the Send button.
    Is it working?
    – Gokul
    Issue in Validator #27237
    Hi Gokul,
    The demo is working fine. I do not see any problem in it.
    Issue in Validator #27529
    gokul
    Hai Peter,
    Thanks for you reply.
    Now I have another one concern,
    See the below code,
    $(‘#frmRegister’).jqxValidator({
    hintType: ‘label’,
    focus: true,
    position: ‘right’,
    rules: [
    { input: ‘#txtFirstName’, message: ‘Username is required!’, action: ‘keyup, blur’, rule: ‘required’ },
    { input: ‘#txtLastName’, message: ‘Lastname is required!’, action: ‘keyup, blur’, rule: ‘required’ }
    I specified hintType as ‘label’ and position as ‘right’. But the error message showing the bottom of the control (textbox) only, not in the right side of the control.
    Gokul
    Issue in Validator #27534
    Hi Gokul,
    Label is not a Tooltip so when it is inserted after your box, if there’s not enough space, it will be displayed below it. In short, you should not set “position” when hintType is “label”.
