jQuery UI Widgets Forums Grid Issue in combination of filtering and partialview
This topic contains 2 replies, has 2 voices, and was last updated by  ducpm 10 years, 7 months ago.
  • ducpm
    Hi community,
    Im using jqwidgets version 3.5.0 in .net MVC project. My view display a data grid (with context menu) and a partial view below but when I activate the attribute “Filterable:true”, the view’s structure will be destroyed: the grid disapear and the components of partialview will be pushed up. When I remove the attribute filterable, the view will be ok with partialview (the grid cannot filter ).
    Please, give me some advises. Thanks in advance!
    http://imageshack.com/a/img661/1249/sB4vdY.png
    http://imageshack.com/a/img661/4100/WUwOMq.png
    http://imageshack.com/a/img673/5827/wN3NIe.png
    It’s my code for the view:
    //========================================================== Load dropdownlist for popup========================================
    var dataDropdownlist = @Html.Raw(ViewBag.DocTypeList);
    var sourceDropdownlist =
    localdata: dataDropdownlist,
    datatype: “array”,
    { name: ‘DocTypeID’ },
    { name: ‘DocTypeName’ }
    //,async: false
    var dataAdapterDropdownlist = new $.jqx.dataAdapter(sourceDropdownlist);
    // Create a jqxDropDownList
    $(“#popupDocType”).jqxDropDownList({
    selectedIndex: 0,
    theme:’ui-start’,
    source: dataAdapterDropdownlist,
    dropDownHorizontalAlignment: ‘right’,
    displayMember: “DocTypeName”,
    valueMember: “DocTypeID”,
    dropDownWidth: 300,
    width: 180, height: 25});
    //=========================================================Load Grid ===========================================================================
    $(document).ready(function ReloadGrid() {
    var dataGrid = @Html.Raw(ViewBag.DocList);
    var sourceGrid =
    localdata: dataGrid,
    datatype: “array”,
    datafields:
    { name: ‘DocID’, type: ‘string’ },
    { name: ‘DocName’, type: ‘string’ },
    { name: ‘DocNote’, type: ‘string’ },
    { name: ‘DocType’, type: ‘string’ },
    { name: ‘DocLocation’, type: ‘string’ },
    { name: ‘UploadDate’, type: ‘string’ },
    { name: ‘UserUpload’, type: ‘string’ },
    { name: ‘LastUserUpdate’, type: ‘string’ },
    { name: ‘Active’, type: ‘string’ }
    //{ name: ‘Active’, type: ‘string’ }
    commit(true);
    var addfilter = function () {
    var filter_or_operator = 1;
    var filtervalue = ‘1’;
    var filtercondition = ‘chứa’;
    var filter1 = filtergroup.createfilter(‘stringfilter’, filtervalue, filtercondition);
    filtervalue = ‘2’;
    filtercondition = ‘bắt đầu bằng’;
    var filter2 = filtergroup.createfilter(‘stringfilter’, filtervalue, filtercondition);
    filtergroup.addfilter(filter_or_operator, filter2);
    // add the filters.
    $(“#jqxgrid”).jqxGrid(‘addfilter’, ‘firstname’, filtergroup);
    // apply the filters.
    $(“#jqxgrid”).jqxGrid(‘applyfilters’);
    var dataAdapterGrid = new $.jqx.dataAdapter(sourceGrid);
    width: 1250,
    source: dataAdapterGrid,
    altrows: true,
    //showfilterrow: true,
    ready: function () {
    addfilter();
    selectionmode: ‘multiplerowsextended’,
    theme: ‘fresh’,
    autoshowfiltericon: true,
    { text: ‘Mã số’, datafield: ‘DocID’, width: 70, align: ‘center’ },
    { text: ‘Tên văn bản’, datafield: ‘DocName’, width: 200, align: ‘center’ },
    { text: ‘Loại’, datafield: ‘DocType’, width: 200, align: ‘center’ },
    { text: ‘Tên file’, datafield: ‘DocLocation’, width: 100, align: ‘center’ },
    { text: ‘Người upload’, datafield: ‘UserUpload’, width: 150, align: ‘center’ },
    { text: ‘Ngày upload’, datafield: ‘UploadDate’, width: 100, align: ‘center’ },
    { text: ‘Người update cuối’, datafield: ‘LastUserUpdate’, width: 150, align: ‘center’ },
    { text: ‘Ghi chú’, datafield: ‘DocNote’, width: 270, align: ‘center’ },
    { text: ‘Tình trạng’, datafield: ‘Active’, width: 80, align: ‘center’ }
    //$(‘#events’).jqxPanel({ width: 300, height: 80 });
    //$(“#jqxgrid”).on(“filter”, function (event) {
    // $(“#events”).jqxPanel(‘clearcontent’);
    // var filterinfo = $(“#jqxgrid”).jqxGrid(‘getfilterinformation’);
    // var eventData = “Triggered ‘filter’ event”;
    // for (i = 0; i < filterinfo.length; i++) {
    // var eventData = “Filter Column: ” + filterinfo[i].filtercolumntext;
    // $(‘#events’).jqxPanel(‘prepend’, ‘<div style=”margin-top: 5px;”>’ + eventData + ‘</div>’);
    // create context menu
    var contextMenu = $(“#Menu”).jqxMenu({ width: 200, height: 58, autoOpenPopup: false, mode: ‘popup’});
    $(“#jqxgrid”).on(‘contextmenu’, function () {
    return false;
    // handle context menu clicks.
    $(“#Menu”).on(‘itemclick’, function (event) {
    var args = event.args;
    var rowindex = $(“#jqxgrid”).jqxGrid(‘getselectedrowindex’);
    if ($.trim($(args).text()) == “Sửa đổi thông tin”) {
    editrow = rowindex;
    $(“#popupWindow”).jqxWindow({ position: { x: parseInt(offset.left) + 60, y: parseInt(offset.top) + 60} });
    $(“#popupDocID”).val(dataRecord.DocID);
    $(“#popupDocName”).val(dataRecord.DocName);
    $(“#popupDocType”).val(dataRecord.DocType);
    $(“#popupDocNote”).val(dataRecord.DocNote);
    // show the popup window.
    $(“#popupWindow”).jqxWindow(‘show’);
    else {
    var data = $(‘#jqxgrid’).jqxGrid(‘getrowdata’, rowindex);
    Download(data.DocID);
    $(“#jqxgrid”).on(‘rowclick’, function (event) {
    if (event.args.rightclick) {
    $(“#jqxgrid”).jqxGrid(‘selectrow’, event.args.rowindex);
    contextMenu.jqxMenu(‘open’, parseInt(event.args.originalEvent.clientX) + 5 + scrollLeft, parseInt(event.args.originalEvent.clientY) + 5 + scrollTop);
    return false;
    $(“#popupWindow”).jqxWindow({ width: 300, resizable: false, isModal: true, autoOpen: false, cancelButton: $(“#Cancel”), modalOpacity: 0.01 });
    // update the edited row when the user clicks the ‘Save’ button.
    if (editrow >= 0) {
    var row = { DocID: $(“#popupDocID”).val(), DocName: $(“#popupDocName”).val(), DocType: $(“#popupDocType”).val(),
    DocNote: $(“#popupDocNote”).val()
    var rowid = $(“#jqxgrid”).jqxGrid(‘getrowid’, editrow);
    UpdateDocInfo(row);
    $(“#jqxgrid”).jqxGrid({ autoshowfiltericon: !event.args.checked });
    //=================================================== POST GET DATA =================================================================================
    function PostData(DocID) {
    var url=”/DocManagement/Test”;
    $.get(url, {DocID:DocID});
    function Download(DocID)
    var data= DocID ;
    var getUrl = ‘@Url.Action(“Test”, “DocManagement”)’;
    $.ajax(getUrl, {
    //contentType: ‘application/json;charset=utf-8′,
    //dataType:’json’,
    type:’GET’,
    data: {DocID: data},
    success: function(d){
    if(d.success){
    Window.location = getUrl + “?DocID=” +d.DocID;
    function UpdateDocInfo(row)
    var data= JSON.stringify(row) ;
    var getUrl = ‘@Url.Action(“Edit”, “DocManagement”)’;
    $.ajax(getUrl, {
    dataType:’json’,
    type:’POST’,
    data: data,
    <body class=’default’>
    <table id=”tableData”>
    <tr>
    <td>
    <div id=’jqxWidget’ style=”font-size: 13px; font-family: Verdana; float: left;”>
    <div id=”jqxgrid”>1234</div>
    <div style=’margin-top: 20px;’> </div>
    <div style=”margin-top: 30px;”>
    <div id=”cellbegineditevent”></div>
    <div style=”margin-top: 10px;” id=”cellendeditevent”></div>
    <div id=”popupWindow”>
    <div>Edit</div>
    <div style=”overflow: hidden;”>
    <table>
    <tr>
    <td align=”right”>Mã văn bản</td>
    <td align=”left”><input id=”popupDocID” name=”DocID” readonly=”true” /></td>
    </tr>
    <tr>
    <td align=”right”>Tên văn bản</td>
    <td align=”left”><input id=”popupDocName” name=”DocName” /></td>
    </tr>
    <tr>
    <td align=”right”>Loại văn bản</td>
    <td align=”left”><div id=”popupDocType” type=”text” name=”DocType”></div></td>
    </tr>
    <tr>
    <td align=”right”>Ghi chú</td>
    <td align=”left”><input id=”popupDocNote” name=”DocNote” /></td>
    </tr>
    <tr>
    <td align=”right”></td>
    <td style=”padding-top: 10px;” align=”right”>
    <input style=”margin-right: 5px;” type=”submit” id=”Save” value=”Save” />
    <input id=”Cancel” type=”button” value=”Cancel” />
    </td>
    </tr>
    </table>
    <div id=’Menu’>
    • Sửa đổi thông tin
    • Tải về
    </td>
    </tr>
    </table>
    <div>
    <section id=”Upload”>
    @{ Html.RenderAction(“UploadFile”, “DocManagement”); }
    </section>
    Hello ducpm,
    I would suggest you to check for missing required javascript references like jqxgrid.filter.js, jqxlistbox.js, jqxdropdownlist.js.
    ducpm
    Thanks for your support. I’ve just found out that when I removed all of javascript references in partial view (which are the same in the view), my app totally runs well. I don’t know why, maybe there were some interupted between the javascript references.
    Thanks again,
