jQuery UI Widgets Forums Grid Issue column header change color when resize
This topic contains 1 reply, has 2 voices, and was last updated by  Martin 4 years ago.
  • arsue787
    Hi guys,
    I have an issue. Currently I have one grid with column group, I differentiate the column group by color (define in CSS) when I resize the one of the column or resize the window browser, the last column group and normal column background color automatically change to the default color.
    Here is example of my code Example
    in that example (jSfiddle) I don’t have this issue but in my program its not working. Is it any advice to solve this issue?
    Thank you
    Arsue787
    Martin
    Hello Arsue787,
    I have tested the example that you have sent but could not reproduce such issue.
    Could you provide some more information? Do you have column reorder enabled? Have you inspected the styles of the column which color changes?
    Martin Yotov
    https://www.jqwidgets.com/
