jQuery UI Widgets Forums Getting Started installation guide
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 7 years, 2 months ago.
  • installation guide #99141
    amitkmrchouhan
    Hi admin,
    I done all the things provided in the documentation.
    But i don’t know where i placed the downloaded folder jqwidgets .
    I am new to react .
    So please help me.
    I setup package.json file and config file also as suggested by documentation.
    Whenever I do import JqxBarGauge from ‘jqwidgets-react/react_jqxbargauge.js’;
    Its shows me error like this.
    Failed to compile.
    Error in ./src/layouts/report_definition/step_one.js
    Module not found: ‘jqwidgets-react/react_jqxbargauge.js’ in /home/amit/identity_pp/src/layouts/report_definition
    @ ./src/layouts/report_definition/step_one.js 61:25-72
    installation guide #99167
    Hi Amit,
    I would like to suggest you to install through npm the “create-react-app” npm package. More information about it, you may see here: https://www.jqwidgets.com/reactjs-components-documentation/documentation/create-react-app/index.htm. This package contains a demo with our components that is ready to be used. From it, most of our customers get started very easily.
    Hope this helps.
