jQuery UI Widgets Forums Plugins Data Adapter input id – sql – output city
This topic contains 3 replies, has 2 voices, and was last updated by  szoron 11 years, 3 months ago.
  • input id – sql – output city #52174
    szoron
    Hello!
    szeretnék,
    beírok egy azonosítót,
    megnyomok egy gombot
    és mysql-ből kiolvassa az azonosító tartozó várost
    button works as condescending, but does not return a value. the php query works because the combo box into returns
    pls help. thx
    point
    input id – sql – output city #52181
    Hi szoron,
    Unfortunately, we do not understand your question. If you would like to provide a sample which demonstrates your application scenario, please prepare it in http://jsfiddle.net/ and share it so we can see what you mean.
    input id – sql – output city #52187
    szoron
    sorry this is task
    I want to, I provide an ID, press a button and mysql out of town reads for the identification of
    input id – sql – output city #52191
    szoron
    ready
    		var ordersSource =
    				{ name: 'ml_num'},
    				{ name: 'address'},
    				{ name: 'city'},
    				{ name: 'tch'}
    			url: 'cascadingcombobox_data.php',
    			cache: false,
    			async: false
                var dataAdapter = new $.jqx.dataAdapter(ordersSource, {
                    loadComplete: function () {
                        // get data records.
                        var records = dataAdapter.records;
                         var record = records[0];
                        $("#addr").val(record.address);
                        $("#tch").val(record.tch);
    		var ordersAdapter = new $.jqx.dataAdapter(ordersSource);
                    // create jqxInput
                    $("#input").jqxInput({ placeHolder: "Munkalapszám...", height: 23, width: 250, minLength: 1 });
                    $("#addr").jqxInput({
                    	placeHolder: "cím...",
                    	height: 23,
                    	width: 250,
                    	displayMember: 'address',
                    	minLength: 1
                    $("#tch").jqxInput({
                    	placeHolder: "technikus...",
                    	height: 23,
                    	width: 250,
                    	displayMember: 'tch',
                    	minLength: 1
                    $("#search").bind('click', function (event) {
    	                var value = $("#input").val();
    	                ordersSource.data = {ml_num : value};
    	                dataAdapter.dataBind();
