jQuery UI Widgets Forums Grid Input field in row detail not working
This topic contains 4 replies, has 2 voices, and was last updated by  Peter Stoev 10 years, 5 months ago.
  • Input field in row detail not working #66263
    Alantod17
    I have some input fields in my row detail and when I am trying to copy the text in the input filed the clipboard does not catch anything. right click and choose copy do not work either. the only way to cope is to select all text in the input tag and right click then use keyboard navigate to copy. it looks like the focus is lost when try to copy. please help
    Input field in row detail not working #66271
    Hi Alantod17,
    You should set your Grid’s “enablebrowserselection” property to true to enable the user selection within details.
    Input field in row detail not working #66361
    Alantod17
    Hi Peter
    Thanks for the reply.
    The “enablebrowserselection” property does not work on my case.
    I find out that all shortcut keys are not working in row detail input field.
    And when I am pressing ctrl key down the focus still on the input tag, but the focus is lost when i am pressing “C” key down.
    Cheers
    Input field in row detail not working #66367
    Alantod17
    Hi Peter
    I also find out that the focus is jump out from input to the div <div tabindex="1" class="jqx-clear jqx-max-size jqx-position-relative jqx-overflow-hidden jqx-background-reset" id="wrapperjqxWidget5cc22c0e">
    please help
    cheers
    Input field in row detail not working #66382
    Hi Alantod17,
    shortcuts are handled by jqxGrid.
