jQuery UI Widgets Forums Grid initrowdetails is not firing in single click
This topic contains 6 replies, has 4 voices, and was last updated by  Goods 10 years, 7 months ago.
  • Peter Stoev
    Hi RajaniKantaPanda,
    initrowdetails is fired just once when the details of a row need to be initialized. Please, take a look at the sample which demonstrates how to use the feature: nestedgrids.htm.
    Sample source code:
    <title id='Description'>This example shows how to display nested Grid plugins.</title>
    <script type="text/javascript" src="../../scripts/jquery-1.7.2.min.js"></script>
    var theme = getTheme();
    var url = "../sampledata/employees.xml";
    { name: 'FirstName' },
    { name: 'LastName' },
    { name: 'Title' },
    { name: 'Address' },
    { name: 'City' },
    root: "Employees",
    record: "Employee",
    datatype: "xml",
    async: false,
    url: url
    var employeesAdapter = new $.jqx.dataAdapter(source);
    var orderdetailsurl = "../sampledata/orderdetails.xml";
    var ordersSource =
    { name: 'EmployeeID' },
    { name: 'ShipName' },
    { name: 'ShipAddress' },
    { name: 'ShipCity' },
    { name: 'ShipCountry' },
    { name: 'ShippedDate' }
    root: "Orders",
    record: "Order",
    datatype: "xml",
    url: orderdetailsurl,
    async: false
    var ordersDataAdapter = new $.jqx.dataAdapter(ordersSource, { autoBind: true });
    orders = ordersDataAdapter.records;
    // create nested grid.
    var initrowdetails = function (index, parentElement, gridElement, record) {
    var id = record.uid.toString();
    var grid = $($(parentElement).children()[0]);
    var filter_or_operator = 1;
    var filtervalue = id;
    var filtercondition = 'equal';
    var filter = filtergroup.createfilter('stringfilter', filtervalue, filtercondition);
    var ordersbyid = [];
    for (var m = 0; m < orders.length; m++) {
    var result = filter.evaluate(orders[m]["EmployeeID"]);
    if (result)
    ordersbyid.push(orders[i]);
    var orderssource = { datafields: [
    localdata: ordersbyid
    if (grid != null) {
    grid.jqxGrid({ source: orderssource, theme: theme, width: 600, height: 200,
    { text: 'Ship Name', datafield: 'ShipName', width: 200 },
    { text: 'Ship Address', datafield: 'ShipAddress', width: 200 },
    { text: 'Ship City', datafield: 'ShipCity', width: 150 },
    { text: 'Ship Country', datafield: 'ShipCountry', width: 150 },
    { text: 'Shipped Date', datafield: 'ShippedDate', width: 200 }
    var photorenderer = function (row, column, value) {
    var name = $('#jqxgrid').jqxGrid('getrowdata', row).FirstName;
    var imgurl = '../../images/' + name.toLowerCase() + '.png';
    var img = '<div style="background: white;"><img style="margin:2px; margin-left: 10px;" width="32" height="32" src="' + imgurl + '"></div>';
    return img;
    var renderer = function (row, column, value) {
    return '<span style="margin-left: 4px; margin-top: 9px; float: left;">' + value + '</span>';
    // creage jqxgrid
    $("#jqxgrid").jqxGrid(
    width: 670,
    height: 365,
    source: source,
    rowdetails: true,
    rowsheight: 35,
    rowdetailstemplate: { rowdetails: "<div id='grid' style='margin: 10px;'></div>", rowdetailsheight: 220, rowdetailshidden: true },
    ready: function () {
    $("#jqxgrid").jqxGrid('showrowdetails', 1);
    { text: 'Photo', width: 50, cellsrenderer: photorenderer },
    { text: 'First Name', datafield: 'FirstName', width: 100, cellsrenderer: renderer },
    { text: 'Last Name', datafield: 'LastName', width: 100, cellsrenderer: renderer },
    { text: 'Title', datafield: 'Title', width: 180, cellsrenderer: renderer },
    { text: 'Address', datafield: 'Address', width: 300, cellsrenderer: renderer },
    { text: 'City', datafield: 'City', width: 170, cellsrenderer: renderer }
    <div id="jqxgrid">
    yusufmendes
    Hi peter,I have two buttons in action column .you said “initrowdetails is fired just once when the details of a row need to be initialized” .when I click first button initrowdetails function called,then I click other button initrowdetails never called again.İn my scenario initrowdetails function should rendered dynamic content according to which button clicked and initrowdetails should not be called justt once time.Are there any initrowdetails settings to enable initrowdetails function to be called more than one time?
    Hi yusufmendes,
    No, initrowdetails is called just one to initialize the row’s details. It’s not possible it to be called more than once after the Grid’s initialization.
    yusufmendes
    what I should to do now?Any workaround solution.I must implement this scenerio.2.5 version or further releases will support this scenario or not?
    Hi yusufmendes,
    Unfortunately, the requested functionality by you is missing. There is no workaround for this version. I will create a work item about it, but I can’t provide a time-frame when or whether this will be implemented.
    Goods
    I know it’s been quite a while since this was posted, but I just ran into the same issue and came up with a fairly simple workaround.
    I have ajax loading dynamic data on initrowdetails, like this:
    var parentHolder = {};
    function initrowdetails(index, parentElement, gridElement, datarecord) {
    if (!parentElement) {
        parentElement = parentHolder[index];
    else {
        parentHolder[index] = parentElement;
    //This if statement exists so that I can get the correct parent element on subsequent calls outside of the jqxGrid API
        url: '/Authorized/GetDynamicData/' + datarecord.Id,
        success: function (html) {
            var content = $('<div />').html(html).find('#DynamicDataDiv');
            $(parentElement).children('.rowdetailWrapper').html(content);
    The problem is, that upon closing the row, opening another one, and the reopening the first one, the first one now had elements from the second one (and initrowdetails wasn’t firing, as the row has already been initialized).
    I simply made a bind:
     $('#Grid').on('rowexpand', function (event) {
        $('.rowdetailWrapper').html(''); //to clear the row details
        var index = $('#Grid').jqxGrid('getrowboundindex', event.args.rowindex);
        var rowdata = $('#Grid').jqxGrid('getrowdata', index);
        initrowdetails(index, false, $('#Grid'), rowdata);//Pass false to get correct parent element from holder
    I know this solution isn’t perfect and seems pretty sloppy, but the whole reason I had to do this was because I was loading dynamic data from an outside source using $.load(), but it was stripping out all the <script> tags on the target page when using a selector (how i use #DynamicDataDiv in the ajax call), and when not using a selector it would load the data and execute the scripts, but then jqxGrid would break (calling $(‘#Grid’).jqxGrid(‘anything here’); would return undefined function or the like in the console, breaking the grid entirely. So I used AJAX to load the whole document instead, and then simply pick out the part I needed. But, like I said before, this started having issues when initrowdetails only got called the first time, causing javascript inside the dynamic data to target not only itself but the same tags from the other rows. I’m sure there were other ways I could have gone about it, like making the selector classes I use unique, but this was a quick and easy way to get it working and working fast.
