jQuery UI Widgets Forums Grid Initial filter not setting condition
This topic contains 3 replies, has 2 voices, and was last updated by  nikitaso 9 years, 11 months ago.
  • Initial filter not setting condition #75011
    nikitaso
    If you run this code in your example, it doesnt set correct filter condition, just sets to first in the list. Or am I doing something wrong?
    `$(document).ready(function () {
    var data = generatedata(500);
    localdata: data,
    datafields:
    { name: ‘date’, type: ‘date’ },
    { name: ‘price’, type: ‘number’ }
    datatype: “array”
    var quantityColumnFilter = function () {
    var filter_or_operator = 1;
    var filtervalue = 7;
    var filtercondition = ‘greater_than’;
    var filter = filtergroup.createfilter(‘numericfilter’, filtervalue, filtercondition);
    filtergroup.addfilter(filter_or_operator, filter);
    return filtergroup;
    $(“#jqxgrid”).jqxGrid(
    width: 850,
    source: adapter,
    showfilterrow:true,
    text: ‘First Name’, datafield: ‘firstname’,
    width: 160
    { text: ‘Last Name’, datafield: ‘lastname’, width: 160 },
    { text: ‘Product’, datafield: ‘productname’, width: 170 },
    { text: ‘Order Date’, datafield: ‘date’, filtertype: ‘date’, width: 160, cellsformat: ‘dd-MMMM-yyyy’ },
    { text: ‘Quantity’, filter: quantityColumnFilter, filtertype:’number’, datafield: ‘quantity’, width: 80, cellsalign: ‘right’ },
    { text: ‘Unit Price’, datafield: ‘price’, cellsalign: ‘right’, cellsformat: ‘c2’ }
    Initial filter not setting condition #75030
    Hi nikitaso,
    It applies the correct filter to the Grid as far as I see. The only what’s not changed is the listbox’s selected item.
    Initial filter not setting condition #75054
    nikitaso
    Yes, it does applies correct filter. But it doesnt select correct item from list box (which is a problem), so if you have initial filter set and then add another filter (filtering another column) – it will use first incorrect condition.
    Is it a bug?
    Initial filter not setting condition #75128
    nikitaso
    is it possible to change listbox item?
