jQuery UI Widgets › Forums › Navigation › NavigationBar, ToolBar, NavBar › Initial display problem
This topic contains 4 replies, has 2 voices, and was last updated by aorlic 12 years, 5 months ago.
AuthorInitial display problem Posts
Hello!
I have this small issue with the display of the NavigationBar. One of the initially closed sections is not fully closed on initial display. If I open this section and close it manually, it is displayed fine.
Plase take a lok at the following image, it has 2 examples of the same problem in two different widgets (marked in red).
Thank you,
Aleks.
Hello aorlic,
With the latest version of jQWidgets (2.5.5), we were not able to reproduce the reported issue. Please, update and share your feedback.
http://www.jqwidgets.com/Unfortunatelly it is still there with the new version. On all browsers.
Here is the significant part of the code:
<div id='pra_nav_filter'> <div>Text search</div><div> <table width='100%'> <tr> <td width='35%'>Text:</td> <td> <input id="npr_txt_keywords" type="text" style="margin:2px;"/> </td> </tr> <tr> <td></td> <td> <div id='pra_chk_search_in_alias'>Search in alias</div> <div id='pra_chk_search_in_name'>Search in name</div> </td> </tr> </table> </div> <div>Status and time</div><div> <table width='100%'> <tr> <td width='35%'>Status:</td> <td> <div id='pra_chk_open'>Open</div> <div id='pra_chk_running'>Running</div> <div id='pra_chk_closed'>Closed</div> </td> </tr> <tr style='margin-top: 15px;'> <td width='30%'>Start after:</td> <td><div id="pra_cal_after"></div></td> </tr> <tr> <td width='30%'>Start before:</td> <td><div id="pra_cal_before"></div></td> </tr> </table> </div> <div>Team</div><div>content</div> <div>Performance</div><div>content</div> </div> and the script... $('#pra_nav_filter').jqxNavigationBar({ width: '100%', theme: PMD.theme }); // Text search filter $("#pra_chk_search_in_alias").jqxCheckBox({ checked: true, animationShowDelay:100, animationHideDelay:100, theme: PMD.theme }); $("#pra_chk_search_in_name").jqxCheckBox({ checked: true, animationShowDelay:100, animationHideDelay:100, theme: PMD.theme }); // Status and time filter $("#pra_chk_open").jqxCheckBox({ checked: true, animationShowDelay:100, animationHideDelay:100, theme: PMD.theme }); $("#pra_chk_running").jqxCheckBox({ checked: true, animationShowDelay:100, animationHideDelay:100, theme: PMD.theme }); $("#pra_chk_closed").jqxCheckBox({ checked: true, animationShowDelay:100, animationHideDelay:100, theme: PMD.theme }); $('#pra_cal_after').jqxDateTimeInput({ theme: PMD.theme, height: 22, value: null }); $('#pra_cal_before').jqxDateTimeInput({ theme: PMD.theme, height: 22, value: $.jqx._jqxDateTimeInput.getDateTime(new Date()) }); // filter button $('#pra_btn_filter').jqxButton({ width: '100%', height: '30px', theme: PMD.theme });
Hi aorlic,
Here is a slightly updated version of your example in jsFiddle (with code). Please check it out and share if you experience any issues.
http://www.jqwidgets.com/Thank you Dimitar, this solved the problem. Thank you very much for the effort and express-help.
