jQuery UI Widgets Forums Grid In jqwidget grid filter not supporting custome format
This topic contains 3 replies, has 2 voices, and was last updated by  Peter Stoev 10 years, 3 months ago.
  • arunthatham
    ie issueHi we use jqwidget grid in which when we filter the record on first filter and clicking on calender we are able to see the filter text box text and calander day as same but after filtering once and opening the filter for second time in text box it shows the filter date correctly on expanding the calender it behave strange by showing some “1914”.
    Please note this issue we are facing only in internet explorer
    What we did is mentioned below:Issue only in Internet explorer
    We have implemented the below code for showing the filter textbox text to be in customization format and we face this issue:
    updatefilterpanel: function (filtertypedropdown1, filtertypedropdown2, filteroperatordropdown, filterinputfield1, filterinputfield2, filterbutton, clearbutton,
    columnfilter, filtertype, filterconditions) {
    if (filtertype == “datefilter”) {
    filterinputfield1.jqxDateTimeInput({ formatString: $.x.y.z.substring(0, $.x.y.z.lastIndexOf(‘y’) + 1) });
    filterinputfield2.jqxDateTimeInput({ formatString: $.x.y.z.substring(0, $.x.y.z.lastIndexOf(‘y’) + 1) });
    Please note we are not able to upload the image to tell on words clearly the filter text box shows date like 01/06/15 and since the column is of date filter we have the calender icon next to the text box on expanding it points to june 01 but year it shows as 1915.Ie issue
    Hi arunthatham,
    If you filter a Date column initialized correctly according to the documentation and your filter widgets is DateTimeInput, your Formatting does not matter at all, all the filtering is done by using JavaScript Date Objects with which our widgets work.
    arunthatham
    in case of declaration we didnt do any mistake we are sneding the data from server to client in a specified format and that is what we are binding to UI declaration as mentioned below in updatefilterpanel we are modifiying and showing the format which works fine in chrome but not in IE.
    var source = {
    type: ‘POST’,
    datatype: ‘json’,
    datafields: [{
    type: ‘date’,
    format: ‘MM/dd/yyyy hh:mm tt’
    Hi arunthatham,
    We cannot reproduce an issue with jqxGrid using the provided information.
