jQuery UI Widgets Forums Grid IE Rendereing Issue
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 12 years, 11 months ago.
  • IE Rendereing Issue #6138
    SRK
    1.After testing Jq Widgets controls in various browsers, i observed in IE data is Rendering very slow(Taking too much time to display the data).
    2. If we use widget grid and widget Popup window(Basically a hidden Div) in the same page, it works fine with Chrome and Firefox but does loading very slowly in all the version of IE and Hidden Div is getting displayed just before the Grid is rendered into the page.
    Please provide some information ASAP.
    /SRK
    IE Rendereing Issue #6139
    IE is much slower browser compared to Chrome, Opera or FF. It is also possible that you have a code which consumes additional time in IE compared to other browsers or there are calls to some functions that affect the performance. I’m afraid that I’m not sure what may be the cause for the behavior you have described and with the information I have. Therefore, providing a small sample in which this can be observed locally will be appreciated.
