jQuery UI Widgets Forums Plugins AngularJS How to use Separate Controller for JqxWindow
This topic contains 7 replies, has 2 voices, and was last updated by  Peter Stoev 10 years, 7 months ago.
  • shan_vs
    FirstPage.html
    <html ng-app="demoApp">
    <title id='Description'>jqxWindow Directive for AngularJS.</title>
    <link rel="stylesheet" href="../css/jqx.base.css" type="text/css" />
    <script type="text/javascript" src="../Tools/angular.min.js"></script>
    <script type="text/javascript" src="../Tools/jquery-1.11.1.min.js"></script>
    <script type="text/javascript" src="../Tools/jqxcore.js"></script>
    <script type="text/javascript" src="../Tools/jqxbuttons.js"></script>
    <script type="text/javascript" src="../Tools/jqxwindow.js"></script>
    <script type="text/javascript" src="../Tools/jqxdropdownlist.js"></script>
    <script type="text/javascript" src="../Tools/jqxlistbox.js"></script>
    <script type="text/javascript" src="../Tools/jqxscrollbar.js"></script>
    <script type="text/javascript" src="../Tools/jqxpanel.js"></script>
    <script type="text/javascript" src="../Tools/jqxangular.js"></script>
    	var demoApp = angular.module("demoApp", [ "jqwidgets" ]);
    	demoApp.controller("demoController", function($scope) {
    		$scope.jqxWindowSettings = {
    			height : 200,
    			width : 200,
    			resizable : false,
    			isModal : true,
    			autoOpen : false,
    			modalOpacity : 0.3
    		$scope.showWindow = function() {
    			$scope.jqxWindowSettings.apply('open');
    		$scope.Ok = function() {
    			$scope.jqxWindowSettings.apply('close');
    		$scope.Cancel = function() {
    	demoApp.controller("windowController", function($scope) {
    		$scope.listBoxSource = [ '1', '2', '3' ]
    		$scope.listBox = {
    			source : $scope.listBoxSource,
    			selectedIndex : 0,
    			width : '65',
    			height : '20',
    	<div ng-controller="demoController">
    		<jqx-window jqx-settings=jqxWindowSettings>
    		<div>Title</div>
    		<div>
    			<div ng-include src="'secondPage.html'"></div>
    		</jqx-window>
    		<jqx-button jqx-on-click="showWindow()">Show Window</jqx-button>
    secondPage.html
    <div ng-controller="windowController">
    	List Box <jqx-drop-down-list jqx-settings="listBox"></jqx-drop-down-list>
    Here ListBox contents not showing in the popup window. How to set separate controller for jqxWindow.?
    Hi shan_vs,
    Widgets are with Isolated Scope which means that Content within widgets are in the Scope of their Parent Widgets.
    The solution is:
    Main.html:
        <link rel="stylesheet" type="text/css" href="../../jqwidgets/styles/jqx.base.css" />
        <script type="text/javascript" src="../../scripts/angular.min.js"></script>
        <script type="text/javascript" src="../../jqwidgets/jqxsplitter.js"></script>
        <script type="text/javascript" src="../../jqwidgets/jqxangular.js"></script>
                    height : 300,
                    width : 300,
                    resizable : false,
                    isModal : true,
                    autoOpen : false,
                    modalOpacity : 0.3
                $scope.listBox = {
                    selectedIndex : 0,
                    width : '65',
                    height : '20',
    <body ng-controller="demoController" class='default'>
    	<div>
    		<jqx-window ng-controller="windowController" jqx-settings=jqxWindowSettings>
    		<div>Title</div>
    		<div>
    			<div ng-include src="'SecondPage.html'"></div>
    		</jqx-window>
    SecondPage.html
    <div>
    shan_vs
    Thanks for your reply.
    <link rel="stylesheet" type="text/css" href="../css/jqx.base.css" />
    <script type="text/javascript" src="../Tools/jqxdata.js"></script>
    			height : 300,
    			width : 300,
    			resizable : false,
    			isModal : true,
    			autoOpen : false,
    			modalOpacity : 0.3
    		$scope.test = "sample text";
    	<div>
    		<jqx-window jqx-settings="jqxWindowSettings" id="window" >
    		<div>Title {{test}}</div>
    		<div>Sample {{test}}</div>
    		</jqx-window>
    </html
    Here how to print the {{test}} scope variable inside <jqx-window>. If I put ng-controller in <jqx-window>, I getting this Error,
    Uncaught TypeError: Object #<Object> has no method 'apply'
    Hi shan_vs.,
    I think I already explained you several times that content within widgets is inside the widget’s scope which is isolated. Please, remember that because it seems that you make the same mistake over and over again. Test the sample which I sent you as it works as expected.
    shan_vs
    Hi peter,
    Thanks for your response. Actually, JqxTabs and jqxWindows are isolated scope, If I use ng-controller again and again, the controller is calling again and again and also the “apply” method is getting error.
    	demoApp.controller("ParentCtrl", function($scope) {
    		$scope.message = "Child updated from parent controller";
    		$scope.clickFunction = function() {
    			$scope.$broadcast('update_parent_controller', $scope.message);
    			height : 300,
    			width : 300,
    			resizable : false,
    			isModal : true,
    			autoOpen : false,
    			modalOpacity : 0.3
    	demoApp.controller("ChildCtrl", function($scope, $rootScope) {
    		alert("ChildCtrl Controller");
    		$scope.message = "Some text in child controller";
    		$scope.$on("update_parent_controller", function(event, message) {
    		$scope.message = message;
    <body>
    	<div ng-controller="ParentCtrl">
    		<jqx-window jqx-settings="jqxWindowSettings" id="window" ng-controller="ChildCtrl">
    		<div>Title</div>
    		<div ng-controller="ChildCtrl">{{message}}</div>
    		</jqx-window>
    		<jqx-tabs>
    		<ul>
    			<li>Tab</li>
    		</ul>
    		<div>
    			<button data-ng-click="clickFunction()">Click</button>
    		</jqx-tabs>
    Here if I put ng-controller=”ParentCtrl” in JqxTabs for scope, I getting this Error Uncaught TypeError: Object #<Object> has no method 'apply' in console when I click the button. How to avoid this error, please provide a sample for isolated scope and to avoid repeating ng-controller.
    Hi shan_vs,
    If you put ng-controller in the Tabs scope, you will create a new instance of that controller and that’s wrong. You should pass data, not to create a new controller.
    Ex:
           var demoApp = angular.module("demoApp", ["jqwidgets"]);
           demoApp.controller("ParentCtrl", function ($scope) {
                   height: 300,
                   width: 300,
                   resizable: false,
                   isModal: true,
                   autoOpen: false,
                   modalOpacity: 0.3
               $scope.clickFunction = function () {
           demoApp.controller("ChildCtrl", function ($scope, $rootScope) {
               $scope.$on("update_parent_controller", function (event, message) {
    <body ng-controller="ParentCtrl">
    	<div>
    		<jqx-window jqx-settings="jqxWindowSettings" id="window">
    		<div>Title</div>
    		<div>{{message}}</div>
    		</jqx-window>
    		<jqx-tabs jqx-data="clickFunction">
    		<ul>
    			<li>Tab</li>
    		</ul>
    		<div>
    			<button data-ng-click="data()">Click</button>
    		</jqx-tabs>
    shan_vs
    Hi peter,
    Thanks a lot. If I have only one function means, I can use Jqx-data. Suppose if the controllers have multiple functions, How I can use that functions inside docking or window.
    Hi shan_vs,
    jqx-data can point to any object. This basically means that you can make it to point to an object which contains 2 or 200 functions or make it to point to your scope. Then access your things in the content using data.member notation where member is property or function.
