jQuery UI Widgets Forums General Discussions Navigation Menu, Context Menu How to use hashchange and url: method
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 11 years ago.
  • How to use hashchange and url: method #57029
    Funsho
    Hello, Can anyone help me on how I can use haschange to switch between url files in my web directory without refreshing the menu bar. I am using the menu-fluid-size.htm demo in the jqxmenu folder. I a have couple of web pages saved in different directory. I want to click each item on the dropdown menu and load the corresponding pages without refreshing the menu. I got a demo similar to this, but it can only switch between form tags. I want such that will load pages i declare e.g url: ‘myhome/octa.htm’ in the hashchange function
    $(window).hashchange({
    hash: “#!/login/”,
    onSet: function() {
    $(“#login-form”).show();
    onRemove: function() {
    $(“#login-form”).hide();
    // Attach multiple callbacks to different hashes
    $(window).hashchange([{
    hash: “#!/test1/”,
    onSet: function() {
    alert(“#!/test1/ was set”);
    alert(“#!/test1/ was removed”);
    hash: “#!/test2/”,
    onSet: function() {
    alert(“#!/test2/ was set”);
    Show login form
    Hide login form
    Go to #!/test1/
    Go to #!/test2/
    <small>You can also trigger all events manually by just changing the hash part of the page url.</small>
    <form id=”login-form” action=”.” style=”display: none;”>
    <label for=”username”>Username</label>
    <input id=”username” type=”text”>
    <label for=”password”>Password</label>
    <input id=”password” type=”password”>
    <input type=”submit” value=”Sign in”>
    </form>
    Hi Funsho,
    We don’t know how you can use hashchange. We don’t have such method in our code base.
