I only just recently stumbled upon this beautiful suite of widgets and I’m diving into jqxGrid right now.
One thing I cannot get my head around is the following:
Imagine I have a column ‘Priority’ in my grid. It is fetched from the DB as (eg)
id, name, sortorder
1, High, 30
2, Minor, 10
3, Medium, 20
I want this column to be sorted on the ‘sortorder’ value, while ‘name’ is the display value in the grid and the ‘id’ as the datafield.
One obvious way would be to introduce a hidden column with the sortorders, and sort on that column when the ‘name’ header is clicked, but it appears it needs so much coding that there should be an easier way.
I also looked at the custom sorting example. That might work, but it seems I have to write a custom function for each similar column and I have a few more of them.
It would be appreciated if someone at least could point me in the right direction
