jQuery UI Widgets Forums Grid How to render custom filter within filter row?
This topic contains 6 replies, has 3 voices, and was last updated by  RedantJ 9 years, 3 months ago.
  • Sugoi
    Hi all,
    I have a regular grid with filtering row. Now I have added a custom column which uses a object datatype.
    For this custom column I would like to add a custom filter which can handle the object.
    I can not seem to find any help on this in either the examples, docs or google.
    Anyone have an idea on how to implement this?
    Or does anyone know of a document that explains how to accomplish this?
    Hi Sugoi,
    There is no such document, because at present it is not possible to create a custom filter.
    Sugoi
    Thank you very much for your quick response.
    I’m glad to have a clear answer on this.
    Is there currently any plan to support this in the future?
    Hi Sugoi,
    I will add a work item about that missing feature. However, that would probably be considered when we discuss our Roadmap for Q3 2014.
    RedantJ
    Was this implemented?
    My requirements are to have a combobox on the filterrow.
    If not, is a work-around possible? Such as building a custom filterrow using jqxPanel?
    RedantJ
    I just realized that a work-around solution is possible. There is a search function used here that works the similar to a filter. I’m going to see if I can make something that looks like a filter row, using the toolbar and combobox.
    RedantJ
    This absolutely does work.
    When the source is prepared, remove the filter:
    		{ name: 'ID', type: 'string'},
    		{ name: 'foo1', type: 'string'},
    		{ name: 'foo2', type: 'string'},
    		{ name: 'foo3', type: 'string'}
    		cache: false,
    		url: './data/data.asp',
    //		filter: function()
    //			// update the grid and send a request to the server.
    //			$("#jqxgrid").jqxGrid('updatebounddata', 'filter');
    		root: 'Rows',
    			if (data != null)
    				// Get the total number of records
    Add the filter with the Data Adapter:
    // Add "formatData"
    		formatData: function (data) {
    			data.foo1_startsWith = $("#searchField").val();
    			return data;
    		loadError: function(xhr, status, error)
    			alert(error);
    Then you can design your filter bar using any input method you wish. In this case, the combobox:
    		var me = this;
    		var container = $("<div style='margin: 5px;'></div>");
    		var input = $("<div id='searchField' />");
    		toolbar.append(container);
    		container.append(input);
    		input.addClass('jqx-widget-content-theme');
    		input.addClass('jqx-rc-all-theme');
    		var oldVal = "";
    		input.jqxComboBox({
    			source: ['Item 1', 'Item 2', 'Item 3'],
    			width: 200,
    			height: 23
    		input.on('keydown', function (event) {
    			if (input.val().length >= 2) {
    				if (me.timer) {
    					clearTimeout(me.timer);
    				if (oldVal != input.val()) {
    					me.timer = setTimeout(function () {
    						$("#jqxgrid").jqxGrid('updatebounddata');
    					}, 1000);
    					oldVal = input.val();
    			else {
    Add as many input fields as required and write your server code accordingly.
    In this case, when “Inspect Element” is selected, foo1_startsWith will show up on the Query string parameters.
    It is a lot of code to write, especially if you want to put in more than one filter, which is why there is a filterrow feature in jqxGrid to begin with. This works if you want to program your own filterrow.
