jQuery UI Widgets › Forums › Grid › how to re-calculator in cells?
This topic contains 1 reply, has 2 voices, and was last updated by Dimitar 11 years, 8 months ago.
I have a grid and want re-calc its values then save all of them, how i do this?
Ex:
| field1 | field2 | field3 = field1 + field2
Hello Nguyen Huu Hanh Lam,
Here is a modified version of the example Spreadsheet which achieves the requested functionality:
<!DOCTYPE html><html lang="en"><head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.10.2.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.export.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.edit.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.columnsresize.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.export.js"></script> <script type="text/javascript" src="../../scripts/gettheme.js"></script> <script type="text/javascript"> $(document).ready(function () { var theme = ""; // renderer for grid cells. var numberrenderer = function (row, column, value) { return '<div style="text-align: center; margin-top: 5px;">' + (1 + value) + '</div>'; } var cellvaluechanging = function (row, datafield, columntype, oldvalue, newvalue) { if (datafield == "A") { var valueB = $('#jqxgrid').jqxGrid('getcellvalue', row, "B"); var valueC = parseFloat(newvalue) + parseFloat(valueB ? valueB : 0); $("#jqxgrid").jqxGrid('setcellvalue', row, "C", valueC); } else if (datafield == "B") { var valueA = $('#jqxgrid').jqxGrid('getcellvalue', row, "A"); var valueC = parseFloat(newvalue) + parseFloat(valueA ? valueA : 0); $("#jqxgrid").jqxGrid('setcellvalue', row, "C", valueC); }; }; // create Grid datafields and columns arrays. var datafields = []; var columns = []; for (var i = 0; i < 26; i++) { var text = String.fromCharCode(65 + i); if (i == 0) { var cssclass = 'jqx-widget-header'; if (theme != '') cssclass += ' jqx-widget-header-' + theme; columns[columns.length] = { pinned: true, exportable: false, text: "", columntype: 'number', cellclassname: cssclass, cellsrenderer: numberrenderer }; } datafields[datafields.length] = { name: text }; columns[columns.length] = { text: text, datafield: text, width: 60, align: 'center', cellvaluechanging: cellvaluechanging }; } var source = { unboundmode: true, totalrecords: 100, datafields: datafields, updaterow: function (rowid, rowdata) { // synchronize with the server - send update command } }; var dataAdapter = new $.jqx.dataAdapter(source); // initialize jqxGrid $("#jqxgrid").jqxGrid( { width: 670, source: dataAdapter, editable: true, columnsresize: true, selectionmode: 'multiplecellsadvanced', theme: theme, columns: columns }); $("#excelExport").jqxButton({ theme: theme }); $("#excelExport").click(function () { $("#jqxgrid").jqxGrid('exportdata', 'xls', 'jqxGrid', false); }); }); </script></head><body class='default'> <div id='jqxWidget'> <div id="jqxgrid"> </div> <div style='margin-top: 20px;'> <div style='float: left;'> <input type="button" value="Export to Excel" id='excelExport' /> </div> </div> </div></body></html>
In this case “C” = “A” + “B”.
