jQuery UI Widgets › Forums › Grid › how to pass parameters to web function in jqxgrid
This topic contains 3 replies, has 2 voices, and was last updated by cfernandes 11 years, 1 month ago.
I want to pass the parameter value of a website can not function more. See the code below:
GRID
$(document).ready(function () { var g = $("input[id$='txtGestorPos']").val(); var source = { datatype: "json", data: JSON.stringify({gestor:g}) , datafields: [ { name: 'ID', type: 'number' }, { name: 'NrRegisto', type: 'number' }, { name: 'NrEstabelecimento', type: 'string' }, { name: 'NomeEstabelecimento', type: 'string' }, { name: 'TipoEstabelecimento', type: 'string' }, { name: 'Contacto', type: 'string' }, { name: 'Endereco', type: 'string' }, { name: 'CoordenadasGPS', type: 'string' }, { name: 'DataOperacao', type: 'date' }, ], url: "RegistoVisitasPos.aspx/VisitasAnteriores" }; var dataAdapter = new $.jqx.dataAdapter(source, { contentType: 'application/json; charset=utf-8' }); $("#jqxGridPreviousVisit").jqxGrid( { height:300, width: 720, source : dataAdapter, showfilterrow: true, filterable: true, sortable: true, pageable: true, columns: [ { text: 'ID', datafield: 'ID', hidden: true }, { text: 'Nº da Visita', columntype: 'textbox', filtertype: 'textbox', filtercondition: 'starts_with', datafield: 'NrRegisto', width: 100 }, { text: 'Nº do Comerciante', columntype: 'textbox', filtertype: 'textbox', filtercondition: 'starts_with', datafield: 'NrEstabelecimento', width: 150 }, { text: 'Nome do Comerciante', columntype: 'textbox', filtertype: 'textbox', filtercondition: 'starts_with', datafield: 'NomeEstabelecimento', width: 270 }, { text: 'TipoEstabelecimento', datafield: 'TipoEstabelecimento', hidden: true }, { text: 'Contacto', datafield: 'Contacto', hidden: true }, { text: 'Endereco', datafield: 'Endereco', hidden: true }, { text: 'Coordenadas GPS', datafield: 'CoordenadasGPS', hidden: true }, { text: 'Data da Operação', datafield: 'DataOperacao', filtertype: 'date', width: 200, cellsalign: 'right', cellsformat: 'dd-MM-yyyy' }, ] });
WEBMETHOD
<WebMethod()> _ <ScriptMethod(UseHttpGet:=True, ResponseFormat:=ResponseFormat.Json)> _ Public Shared Function VisitasAnteriores(ByVal gestor As String) As Object Dim visitas As List(Of VisitaAssistencia) Dim jsonSerz As New JavaScriptSerializer() Dim serializedData As String = String.Empty Try visitas = VisitaAssistencia.CarregaAssistencias(gestor) serializedData = jsonSerz.Serialize(visitas) Catch ex As Exception _logger.Error("Erro", ex) End Try Return New JavaScriptSerializer().DeserializeObject(serializedData) End Function
ERROR
Hi cfernandes,
The process of passing parameters is illustrated in this help topic: http://www.jqwidgets.com/jquery-widgets-documentation/documentation/jqxgrid/jquery-grid-extra-http-variables.htm
The example is not complete, I do not know where to put. Only i get error. Can you show me on my example where fit the parameters?
Regards
Already lost my entire day reading all the topics that you recommend everyone to solve this problem.
EX: http://www.jqwidgets.com/community/topic/jqx-dataadapter/
Have you seen that you never helped anyone.
Does anyone on this forum can help?
Will have to look for other widgets?
Does anyone have an example for this case?
