jQuery UI Widgets Forums Lists DropDownList How to original index of array
This topic contains 3 replies, has 2 voices, and was last updated by  Neelam 12 years, 11 months ago.
  • How to original index of array #4843
    Neelam
    I have php array which am using javascript. I want to get original index of selected item on onchange event. But while builing the dropdown indexes get reordered like 0,1,2 and onwards. below is my code.
    var sourceA = new Array();
    groups as $k=> $v)
    echo ‘sourceA[‘.$k.’] = “‘. $v .'”;’;
    $(“#jqDropDownA”).jqxDropDownList({ source: sourceA, selectedIndex: 0, width: ‘150’, height: ’25’ });
    Thanks in advance.
    How to original index of array #4846
    Hi Neelam,
    You can save your “original” index as a value of the items. Each list item has ‘label’ and ‘value’. The ‘label’ is what is going to be displayed, the ‘value’ could be your index.
    For example, for value in the code below, set the “original” index:
    var source = [{
    label: "Hot Chocolate",
    value: "Chocolate Beverage"
    label: "Peppermint Hot Chocolate",
    label: "Salted Caramel Hot Chocolate",
    label: "White Hot Chocolate",
    label: "Caffe Americano",
    value: "Espresso Beverage"
    label: "Caffe Latte",
    label: "Caffe Mocha",
    label: "Cappuccino",
    label: "Caramel Brulee Latte",
    label: "Caramel Macchiato",
    label: "Cinnamon Dolce Latte",
    label: "Eggnog Latte",
    value: "Espresso Beverage",
    label: "Espresso",
    label: "Espresso Con Panna",
    label: "Espresso Macchiato",
    label: "Flavored Latte",
    label: "Gingerbread Latte",
    label: "White Chocolate Mocha",
    label: "Skinny Peppermint Mocha",
    label: "Skinny Flavored Latte",
    label: "Pumpkin Spice Latte",
    label: "Caffe Vanilla Frappuccino",
    value: "Frappuccino Blended Beverage"
    label: "Caffe Vanilla Frappuccino Light",
    label: "Caramel Brulee Frappuccino",
    label: "Caramel Brulee Frappuccino Light",
    label: "Eggnog Frappuccino",
    label: "Mocha Frappuccino",
    label: "Tazo Green Tea Creme Frappuccino",
    // Create a jqxListBox
    $("#jqxWidget").jqxListBox({ source: source, width: 200, height: 250, theme: theme });
    How to original index of array #4848
    Neelam
    Thanks, worked fine after a lot trail.
    How to original index of array #4893
    Neelam
    As you know, I have to access the value of selected item so its necessary to build the array in your given format. But when my ajax request goes, I am building the array in label, value format to access the value but json dont process it the way it should do.
    Shall I need to use json_encode() in php action.
    Thanks in advance.
