jQuery UI Widgets › Forums › Layouts › Splitter › How to load other file into split panel when it loads?
This topic contains 2 replies, has 2 voices, and was last updated by africanfarmer 11 years, 7 months ago.
hi Peter,
i am very like the Loading Split panels with Ajax. in my system designing, i placed all windows in one page which occupy memory largely. so i want to load the contents of split in a window from other files when it opens, and then clear them when it closes.
can you have instruction how to do it?
Hello africanfarmer,
Here is an example:
<!DOCTYPE html><html lang="en"><head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/gettheme.js"></script> <script type="text/javascript" src="../../scripts/jquery-1.10.2.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxsplitter.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxwindow.js"></script> <script type="text/javascript"> $(document).ready(function () { var theme = ""; $("#jqxwindow ").jqxWindow({ height: 310, width: 600, theme: 'summer', autoOpen: false }); $('#jqxSplitter').jqxSplitter({ width: 580, height: 300, theme: theme, panels: [{ size: '50%' }, { size: '50%'}] }); $("#jqxwindow ").on("open", function () { loadPage('pages/ajax1.htm', 1); loadPage('pages/ajax2.htm', 2); }); $("#jqxwindow ").on("close", function () { clearPage(1); clearPage(2); }); var loadPage = function (url, tabIndex) { $.get(url, function (data) { $('#content' + tabIndex).html('<div style="overflow: auto; width: 100%; height: 100%;">' + data + '</div>'); }); }; var clearPage = function (tabIndex) { $('#content' + tabIndex).html(""); }; $("#openWindow").click(function () { $("#jqxwindow").jqxWindow("open"); }); }); </script></head><body class='default'> <button id="openWindow"> Open window</button> <div id='jqxwindow'> <div> Header</div> <div> <div id='jqxSplitter'> <div id="content1"> <img src='../../images/ajax-loader.gif' /> </div> <div id="content2"> <img src='../../images/ajax-loader.gif' /> </div> </div> </div></body></html>
http://www.jqwidgets.com/Dear Dimitar,
Thank you so much for your sample!
can you help on below codes that failed to rebuild the html data after reopen the window? I click menuitem to open the window, and create some html.
function startMenuOpenWindow() {};startMenuOpenWindow.init = function(){ this.openWindowOnClick ();}startMenuOpenWindow.openWindowOnClick = function (){ var startMenuItems = $('#startMenu'); /*get the created window div*/ var startMenuOpenWindowDiv = $(' .startMenuWindows'); startMenuItems.on('itemclick', function (event) { /*get index of clicked menuitem*/ var index = event.args.id; /*get the topmenu item index from the submenu*/ if ( index < 10 && index > 0 ) { cIndex = index - 1; } else { cIndex = _getParentMenuItemId(event) - 1; } for (var i = 0; i < startMenuOpenWindowDiv.length; i++) { var currentWindowId = '#' + startMenuOpenWindowDiv[i].id; //get zindex of the opened window var zIndex = $(currentWindowId).jqxWindow('zIndex'); if ( i == cIndex ) { _openWindow($(currentWindowId)); //make it on the top of all windows when opens $(currentWindowId).css('z-index', '' + (zIndex + 10 ) ); } else { /*对于已经打开的窗口,放到后面去*/ $(currentWindowId).css('z-index', '' + (zIndex - 10 ) ); } } }); startMenuOpenWindowDiv.on('close', function() { clearPage(startMenuOpenWindowDiv.children()); })}
