jQuery UI Widgets Forums Angular How to include jq widgets in angular 2 project
This topic contains 7 replies, has 4 voices, and was last updated by  steffn 7 years, 11 months ago.
  • praneeth
    I am trying to include jq widgets in my project but i did not found the right way to do it.Should I go with npm or down;load an include folder.Can any one please help.Thanks.
    Stanislav
    Hello praneeth,
    You can download it from our web site and then put this two folders in the main directory of your project:
    jqwidgets
    jqwidgets-ts
    Stanislav
    praneeth
    Hi Stanislav,
    I included the 2 folders and some .js files in index.html it worked but when i run the project again it shows lots of error like this
    src/app/grid/jqwidgets-ts/angular_jqxbargauge.ts(308,8): error TS7006: Parameter ‘value’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxbulletchart.ts(276,8): error TS7006: Parameter ‘value’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxbuttons.ts(280,8): error TS7006: Parameter ‘value’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxcalendar.ts(530,8): error TS7006: Parameter ‘date’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxcalendar.ts(530,14): error TS7006: Parameter ‘date2’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxcalendar.ts(531,11): error TS2663: Cannot find name ‘value’. Did you mean the instance member ‘this.value’?
    src/app/grid/jqwidgets-ts/angular_jqxcheckbox.ts(291,8): error TS7006: Parameter ‘value’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxcombobox.ts(658,8): error TS7006: Parameter ‘value’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxcomplexinput.ts(288,11): error TS2663: Cannot find name ‘value’. Did you mean the instance member ‘this.value’?
    src/app/grid/jqwidgets-ts/angular_jqxdatetimeinput.ts(503,8): error TS7006: Parameter ‘value’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxdatetimeinput.ts(503,15): error TS7006: Parameter ‘value2’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxdropdownlist.ts(609,8): error TS7006: Parameter ‘value’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxeditor.ts(272,8): error TS7006: Parameter ‘value’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxformattedinput.ts(360,8): error TS7006: Parameter ‘value’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxgauge.ts(335,8): error TS7006: Parameter ‘value’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxgrid.ts(100,27): error TS2300: Duplicate identifier ‘attrLocalization’.
    src/app/grid/jqwidgets-ts/angular_jqxgrid.ts(696,4): error TS2393: Duplicate function implementation.
    src/app/grid/jqwidgets-ts/angular_jqxgrid.ts(896,4): error TS2393: Duplicate function implementation.
    src/app/grid/jqwidgets-ts/angular_jqxinput.ts(324,8): error TS7006: Parameter ‘value’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxknob.ts(343,8): error TS7006: Parameter ‘value’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxlineargauge.ts(345,8): error TS7006: Parameter ‘value’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxlinkbutton.ts(279,8): error TS7006: Parameter ‘value’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxlistbox.ts(590,8): error TS7006: Parameter ‘value’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxmaskedinput.ts(240,8): error TS7006: Parameter ‘value’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxnavigationbar.ts(321,8): error TS7006: Parameter ‘value’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxnumberinput.ts(411,8): error TS7006: Parameter ‘value’ implicitly has an ‘any’ type.
    src/app/grid/jqwidgets-ts/angular_jqxpasswordinput.ts(284,8): error TS7006: Parameter ‘value’ implicitly has an ‘any’ type.
    Its a blocking issue and I am unable to start the project.Can you please help me.Thanks.
    Stanislav
    Hello praneeth,
    Thanks for your report, the problem will be fixed in the next update.
    For now make this argument of type any(go to the file, find the line it says the error is on, and place a type.)
    Example:
    Before:
    val(value): any {....}
    Now:
    val(value: any): any {....}
    Stanislav
    steffn
    i am using jQWidgets v4.5.3 (2017-June). But recieve this ERR by including the jqx navigationbar in my project:
    ERROR in /home/steffen/WebstormProjects/jqwidgets-ts/jqwidgets.d.ts (14,18): Duplicate identifier 'widget'.
    ERROR in /home/steffen/WebstormProjects/TestMenue/node_modules/jqwidgets-framework/jqwidgets-ts/jqwidgets.d.ts (18,18): Duplicate identifier 'widget'.
    Could you please help me?
    I thought the ERR was fixed by v4.5.3 ?
    Thanks!
    steffn
    Sorry, too stupid.
    i solved the issue…
    I used the the same typescript file twice.
    Ivo Zhulev
    Hi steffn,
    I recommend updating to jQWidgets latest version.
    Ivo
    steffn
    Hi Ivo,
    thanks i just updated for the latest version.
    But i get this ERR all the time:
    ERROR TypeError: a(...)[c] is not a function
        at Object.createInstance (eval at webpackJsonp.5.module.exports (addScript.js:9), <anonymous>:8:17924)
        at jqxDropDownButtonComponent.createComponent (angular_jqxdropdownbutton.ts:111)
        at jqxDropDownButtonComponent.ngOnInit (angular_jqxdropdownbutton.ts:48)
        at checkAndUpdateDirectiveInline (core.es5.js:10834)
        at checkAndUpdateNodeInline (core.es5.js:12330)
        at checkAndUpdateNode (core.es5.js:12269)
        at debugCheckAndUpdateNode (core.es5.js:13130)
        at debugCheckDirectivesFn (core.es5.js:13071)
        at Object.eval [as updateDirectives] (Layer1Component.html:4)
        at Object.debugUpdateDirectives [as updateDirectives] (core.es5.js:13056)
    The Error points on my injector in my app.component.html:
    <div>
      <app-layer1></app-layer1>
    And with the layer1 component i want to inject the jqwidget tree.
    layer1.component.ts:
    import { Component, ViewChild } from '@angular/core';
    import { jqxTreeComponent } from '../../../node_modules/jqwidgets-framework/jqwidgets-ts/angular_jqxtree';
    import { jqxDropDownButtonComponent } from '../../../node_modules/jqwidgets-framework/jqwidgets-ts/angular_jqxdropdownbutton';
    @Component({
      selector: 'app-layer1',
      templateUrl: './layer1.component.html',
      styleUrls: ['./layer1.component.css']
    export class Layer1Component {
      @ViewChild('myTree') myTree: jqxTreeComponent;
      @ViewChild('myDropDownButton') myDropDownButton: jqxDropDownButtonComponent;
      myTreeOnInitialized(): void {
        this.myDropDownButton.setContent('<div style="position: relative; margin-left: 3px; margin-top: 4px;">Home</div>');
      myTreeOnSelect(event: any): void {
        let item = this.myTree.getItem(event.args.element);
        let dropDownContent = '<div style="position: relative; margin-left: 3px; margin-top: 4px;">' + item.label + '</div>';
        this.myDropDownButton.setContent(dropDownContent);
    By debugging in Webstorm i get the Error from this line in the layer1.component.ts:
    Thank you very much!
