jQuery UI Widgets Forums Grid How to get row index problem
This topic contains 2 replies, has 2 voices, and was last updated by  joe cx 10 years, 6 months ago.
  • How to get row index problem #65747
    joe cx
    Hi All,
    Im new in jqxgrid. I have a problem when i trying to add selectionmode: ‘multiplecellsadvanced’ in this example Create, Remove, Update.
    The problem is button Delete didnt work properly. i think because the getselectedrowindex method, but i dont know what the corect method should be used. Sorry for my bad english 😀
    Thank’s for any reply
    How to get row index problem #65760
    Hi joe cx,
    In cell selection mode, you should use API for getting selected cells because you don’t have selected row and respectively getselectedrowindex will return most probably -1 because there’s no selected row.
    How to get row index problem #65957
    joe cx
    Thank you for the quick reply. I’ve read the documentation & i changed my code like this :
    `var selectedrowindex = -1;
    $(“#jqxgrid”).on(‘cellselect’, function (event) {
    selectedrowindex = event.args.rowindex;
    $(“#removebutton”).on(‘click’, function () {
    var id = $(“#jqxgrid”).jqxGrid(‘getrowid’, selectedrowindex);
    var commit = $(“#jqxgrid”).jqxGrid(‘deleterow’, id);
    Am i doing this right ? Thanks again peter.
    Best regards
    Joe
