jQuery UI Widgets Forums Grid How to get a Column that is not visible
This topic contains 1 reply, has 1 voice, and was last updated by  jose Ivan 12 years, 1 month ago.
  • jose Ivan
    Hi, I have downloaded the last version of JQwidgets… my question it’s how I get a column that’s not visible, something like key value.
    Something like branchDisplay and branchtID… the column branchDisplay it’s the only that show, the other it’s the datasource.
    for (var i = 0; i < count; i++) {
    source.datafields.push({ name: respuesta._datas[i].datafields });
    when I want to get back data information with this method doesn’t work!
    $(‘#jqxgrid’).jqxGrid(‘getcolumn’, ‘branchID’);
    Seems like this method get the visible Columns…
    Any Idea?
    Thanks !
    jose Ivan
    Other example it’s a registerID this field doesn’t show but it’s exist in datafield array but not in columntext … so if I would like set a cellvalue of any cell that doesn’t show. In version 2.4 it was working fine.
