jQuery UI Widgets Forums Chart How to assign Values to DisplayText in Chart Serires
This topic contains 3 replies, has 2 voices, and was last updated by  Dimitar 12 years, 6 months ago.
  • leopini
    I am trying to set values to ‘DisplayText’ on series parameter in a chart, because we need to show labels according to value from database. I mean we don’t want to set a string but a variable string from a field from the database. These fields already are set on ‘datafields’ parameter:
    { name: ‘Date_Reading’ },
    { name: ‘Id_Reading1’ },
    { name: ‘Id_Reading2’ },
    { name: ‘Id_Reading3’ },
    { name: ‘Id_Reading4’ },
    { name: ‘Id_Reading5’ },
    { name: ‘Name_Reading1’ },
    { name: ‘Name_Reading2’ },
    { name: ‘Name_Reading3’ },
    { name: ‘Name_Reading4’ },
    { name: ‘Name_Reading5’ }
    How can i get this. I have tried to modify parameters on ‘series’ parameter but i can’t get it. This is my current code:
    valueAxis:{
    unitInterval: 10,
    minValue: 0,
    maxValue: 100,
    description: ‘Readings’,
    displayValueAxis: true,
    showGridLines: true,
    tickMarksColor: ‘#888888’
    series: [{ dataField: ‘Id_Reading1’, displayText: source.datafields.push({ name: ‘Name_Reading1’})},
    { dataField: ‘Id_Reading2’, displayText: source.datafields.push({ name: ‘Name_Reading2’})},
    { dataField: ‘Id_Reading3’, displayText: source.datafields.push({ name: ‘Name_Reading3’})},
    { dataField: ‘Id_Reading4’, displayText: source.datafields.push({ name: ‘Name_Reading4’})},
    { dataField: ‘Id_Reading5’, displayText: source.datafields.push({ name: ‘Name_Reading5’})}]
    Thanks in advance
    Hello leopini,
    Here is how to get the values of the datafields as displayText:
    valueAxis:{
    unitInterval: 10,
    minValue: 0,
    maxValue: 100,
    tickMarksColor: ‘#888888′
    series: [{ dataField: 'Id_Reading1', displayText: source.datafields[6].name},
    { dataField: 'Id_Reading2', displayText: source.datafields[7].name},
    { dataField: 'Id_Reading3', displayText: source.datafields[8].name},
    { dataField: 'Id_Reading4', displayText: source.datafields[9].name},
    { dataField: 'Id_Reading5', displayText: source.datafields[10].name}]
    leopini
    Dimitar thanks for your answer.
    I applied that code, however, the string that i get is the name of the field: ‘Name_Reading1’, ….
    I mean, what i need to get is the value of the field. Each one of these fields contain a string stating the name of the variable in the series.
    I need to show that value.
    Example:
    In the database this field ‘Name_Reading1’ = ‘Description Of Temperature’
    ‘Name_Reading2’ = ‘Current Reading’
    ‘Name_Reading3’ = ‘Level of water’
    Now, in the graph the DisplayText must show []’Description Of Temperature’ [] ‘Current Reading’ [] ‘Level of water’
    The values of ‘Name_Reading1’, ‘Name_Reading2’, etc, could change, so, displayText can not be a prefixed string. it mus be read from database by using this fields ‘Name_Reading1’, ‘Name_Reading2’, …
    Thank you again.
    Hi leopini,
    To learn how to bind a jqxChart to a database, please refer to the following entry in the documentation: Bind jqxChart to SQL Database using ASP .NET MVC3.
