Hi
In my angular 8 app, i have loaded the jqxGrid as follows
view
<jqxGrid
[selectionmode]="'checkbox'"
[source]="source"
[theme]="'material'"
[autoheight]="true"
[pageable]="true"
[altrows]="true"
[filterable]="true"
[sortable]="true"
[columns]="columns"
#grid>
</jqxGrid>
compoenent
export class CertificateBuilderComponent implements OnInit, AfterViewInit {
@ViewChild('grid', { static: false }) grid: jqxGridComponent;
columns : any = [
{text: 'Id', datafield: 'id', width : 10},
{text: 'title', datafield: 'title'},
text: 'Edit', width: 100, datafield: 'Edit', columntype: 'button',
cellsrenderer: function (cellvalue, options, rowObject) {
return '<button type="button" class="btn btn-primary" data-toggle="modal" data-target="#exampleModal" data-whatever="" onclick="somet1()">Edit</button>';
//other code here
when the grid loads it shows like this:
But the issue i’m having is, when the user clicks a bootstrap edit button it should fetch the data in that row, how do i do this in angular and also how to an execute a function in the component’s class on that button click?
thanks
