jQuery UI Widgets › Forums › Chart › How could I POST a variable with ajax?
This topic contains 2 replies, has 2 voices, and was last updated by Schmakus 10 years, 4 months ago.
I want so send an ajax request to my php-script. For examble “Cat_ID = 1”, to use this variable as “WHERE”-string for my MySQL-Select.
Here is my Code:function displayDUTproInsert() { function getExportServer() { return 'http://www.jqwidgets.com/export_server/export.php'; } var source = { datatype: "json", datafields: [ { name: 'Anzahl', }, { name: 'Ort'} ], url: 'script/charts.php?select=2' }; var dataAdapter = new $.jqx.dataAdapter(source, { async: false, autoBind: true, loadError: function (xhr, status, error) { alert('Error loading "' + source.url + '" : ' + error); } }); // prepare jqxChart settings var settings = { title: "Prüflinge in den jeweiligen Eingangsregalen", description: "", enableAnimations: true, showLegend: true, showBorderLine: false, legendLayout: { left: 480, top: 160, width: 300, height: 200, flow: 'vertical' }, padding: { left: 5, top: 5, right: 5, bottom: 5 }, titlePadding: { left: 0, top: 0, right: 0, bottom: 10 }, source: dataAdapter, colorScheme: 'scheme03', seriesGroups: [ { type: 'pie', showLabels: true, series: [ { offsetX : 230, dataField: 'Anzahl', displayText: 'Ort', labelRadius: 170, initialAngle: 15, radius: 145, centerOffset: 0, formatFunction: function (value) { if (isNaN(value)) return value; return parseFloat(value) + ' Prüflinge'; }, } ] } ] }; $('#DUTproInsert').jqxChart(settings); $("#jpegButton1").jqxButton({}); $("#pngButton1").jqxButton({}); $("#jpegButton1").click(function () { // call the export server to create a JPEG image $('#DUTproInsert').jqxChart('saveAsJPEG', 'DUTproOrt.jpeg', getExportServer()); }); $("#pngButton1").click(function () { // call the export server to create a PNG image $('#DUTproInsert').jqxChart('saveAsPNG', 'DUTproOrt.png', getExportServer()); }); // auto update timer var ttimer = setInterval(function () { $('#DUTproInsert').jqxChart('update'); }, 3000); }; // Display Charts displayDUTproInsert();
Thank you for your help. I’m a newbie.
Hello Schmakus,
You can do this by setting the source data:
var source = { datatype: "json", datafields: [{ name: 'Anzahl', }, { name: 'Ort' } ], data: { Cat_ID: 1 }, url: 'script/charts.php?select=2' };
We also have multiple PHP integration examples and help topics that you may find useful.
http://www.jqwidgets.com/Great, so easy….
Thank you!
