jQuery UI Widgets Forums Grid how can i add a checkbox at first column
This topic contains 4 replies, has 2 voices, and was last updated by  jose Ivan 13 years, 1 month ago.
  • how can i add a checkbox at first column #3456
    jose Ivan
    hi i would like to add at first column a checkbox , this is if the end user want select all the row o rows for example to delete .
    $("#jqxgrid").bind('bindingcomplete', function () {
    numColumns = $("#jqxgrid").jqxGrid('columns').length();
    lascolumn = numColumns - 1;
    numrow = $("#jqxgrid").jqxGrid('getdatainformation').rowscount;
    lasrow = $("#jqxgrid").jqxGrid('getdatainformation').rowscount - 2;
    var localizationobj = $("#jqxgrid").jqxGrid('gridlocalization');
    localizationobj.currencysymbol = "C$";
    localizationobj.currencysymbolposition = "before";
    localizationobj.decimalseparator = ".";
    localizationobj.thousandsseparator = ",";
    localizationobj.pagergotopagestring = "Ir a: ";
    localizationobj.pagerrangestring = " de ";
    localizationobj.percentsymbol = "%";
    localizationobj.pagerpreviousbuttonstring = "Previa";
    localizationobj.pagernextbuttonstring = "siguiente";
    localizationobj.pagershowrowsstring = "Mostrar filas:";
    // apply localization.
    $("#jqxgrid").jqxGrid('render');
    // initialize jqxGrid
    width: 1200,
    altrows: true,
    enablehover: true,
    enabletooltips: true,
    enableanimations: true,
    theme: 'summer',
    keyboardnavigation: true,
    editmode: /*'selectedcell',*/'programmatic',
    selectionmode: 'singlecell',
    // rendergridrows: function () {
    // return dataadapter.records + 5;
    { text: 'fila', columntype: 'checkbox', width: 50 },
    { text: 'id', columntype: 'textbox', datafield: 'id', width: 50,
    change: function (s, e) {
    alert()
    { text: 'Numero de Cuenta', columntype: 'textbox', datafield: 'Account', width: 150 },
    { text: 'Descripción', datafield: 'Description', columntype: 'textbox', width: 170 },
    { text: 'Activo', datafield: 'available', columntype: 'checkbox', width: 67 },
    { text: 'Debe', datafield: 'Debe', width: 70, cellsalign: 'right', cellsformat: 'c2', columntype: 'textbox'
    // validation: function (cell, value) {
    // var al = cell;
    // var k = value;
    // initeditor: function (row, cellvalue, editor) {
    // editor.jqxNumberInput({ digits: 3 });
    { text: 'Haber', datafield: 'Haber', width: 70, cellsalign: 'right', cellsformat: 'c2', columntype: 'numberinput',
    return true;
    { text: 'notas', datafield: 'nota', columntype: 'textbox', width: 250 }
    as you can see i created a checkbox column but it doesn’t have an field associated but when a i check one they disappear
    function GetnewRow() {
    var row = {};
    row["id"] = 9;
    row["available"] = 0;
    row["Account"] = "";
    row["Description"] = "";
    row["Debe"] = "";
    row["Haber"] = "";
    row["nota"] = "";
    return row;
    and my fuction addrow
    function insertrow() {
    var something = GetnewRow();
    var value = $('#jqxgrid').jqxGrid('addrow', null, something);
    return value;
    how can i add a checkbox at first column #3458
    jose Ivan
    and i would like to bind a event change () i see the events of checkbox what part of code i can do this…
    maybe in cellsrenderer: function (row, column, value) {};
    how can i add a checkbox at first column #3465
    Hi jose Ivan,
    The ‘cellendedit’ event is raised when the value of a cell is changed. The event provides as arguments the edit row, column and cell value. It is also necessary to set the column’s datafield property to a valid field in your datasource.
    To change the built-in rendering of a column header, you need to create a custom renderer function that returns a new HTML string. The column’s definition should include a renderer property that points to your custom renderer function.
    jose Ivan
    hi thanks for reply …. but i think that don’t understand me …. i want add a column checkbox and when the end user check this select the row and to delete it .
    so i want to bind the event change of checkbox to a function when find the id of this row but i don’t know what part of my code i have to bind it , maybe in cellsrenderer ?? maybe u can help me
    jose Ivan
    mmm my bad sorry
