jQuery UI Widgets Forums Dialogs and Notifications Window Hide popup if click detected elsewhere
This topic contains 2 replies, has 2 voices, and was last updated by  Nadezhda 10 years, 4 months ago.
  • Hide popup if click detected elsewhere #64978
    arkgroup
    Is it possible to close window when click out site of it?
    I open window on icon click and try to close on body click, but it does not work (icon is in the body)
    Any suggestions?
    Hide popup if click detected elsewhere #65023
    arkgroup
    Looks like this code is working…
    $(document).mouseup(function (e) {
    var container = $(“#popupWindow”);
    if (!container.is(e.target) // if the target of the click isn’t the container…
    && container.has(e.target).length === 0) // … nor a descendant of the container
    $(“#popupWindow”).jqxWindow(‘close’);
    Hide popup if click detected elsewhere #65025
    Nadezhda
    Hello arkgroup,
    You can also use event.stopPropagation(); or event.cancelBubble = true; to stop the click event from bubbling to parent elements. Here are the examples:
    1) event.stopPropagation
    $(document).on("click", function (event) {//second way
         $('#jqxwindow').jqxWindow('close');
    2) event.cancelBubble
    $(document).on("click", function () {
    Nadezhda
