jQuery UI Widgets › Forums › Grid › Help with Edit in ASP.NET
This topic contains 4 replies, has 2 voices, and was last updated by DeeCan 12 years, 2 months ago.
Hi All,
I am trying to make an editable grid in ASP.NET using the Northwind DB example. I use the updaterow function to pass json to the webservice,
where it reads the object and updates the DB with new values. However, I get ‘internal server error’ when I run the code. Please help me fix this.Regards
DeeCanMy javascript file is as follows:
//Getting the source data with ajax GET request
var source = {
{ name: ‘CustomerID’ },
{ name: ‘CompanyName’ },
{ name: ‘ContactName’ },
{ name: ‘ContactTitle’ },
{ name: ‘City’ },
{ name: ‘Country’ },
{ name: ‘Address’}],
type: ‘GET’,
url: ‘Service.asmx/GetCustomers’,updaterow: function (rowid, rowdata, commit) {
//process row data
var data = {
CustomerID: rowdata.CustomerID,
CompanyName: rowdata.CompanyName,
ContactName: rowdata.ContactName,
ContactTitle: rowdata.ContactTitle,
City: rowdata.City,
Country: rowdata.Country,
Address: rowdata.Address
//make ajax call to server
type: “POST”,
url: ‘Service.asmx/UpdateCustomers’,
dataType: “json”,
data: data,
formatdata: function (data) {
var sendjson = JSON.stringify(data);
return sendjson;
commit(true);
alert(errorThrown);
commit(false);
}),$(“#jqxgrid”).jqxGrid(‘updatebounddata’);
};var dataAdapter = new $.jqx.dataAdapter(source, {
alert(error);
downloadComplete: function (data) {
var returnData = {};
returnData.records = data.d;
return returnData;
});$(“#jqxgrid”).jqxGrid({
groupable: true,
{ text: ‘Company Name’, dataField: ‘CompanyName’, columntype: ‘textbox’, width: 250, groupable: false },
{ text: ‘Contact Name’, dataField: ‘ContactName’, columntype: ‘textbox’, width: 150, groupable: false },
{ text: ‘Contact Title’, dataField: ‘ContactTitle’, editable: false, width: 180 },
{ text: ‘Address’, dataField: ‘Address’, editable: false, width: 180 },
{ text: ‘City’, dataField: ‘City’, editable: false, width: 80 },
{ text: ‘Country’, dataField: ‘Country’, editable: false }
});My webservice code uses SQL server Tableadapter to update the DB.
[WebMethod]
[ScriptMethod(UseHttpGet = false)]
public void UpdateCustomers(string jsonobj)
{JavaScriptSerializer js = new JavaScriptSerializer();
UpdateData ud = js.Deserialize(jsonobj);try
CustomersTableAdapter tableadapter = new CustomersTableAdapter();
tableadapter.UpdateCustomerQuery(ud.CompanyName, ud.ContactName,
ud.ContactTitle, ud.City, ud.Country, ud.Address, ud.CustomerID);
catch(Exception ex)
Console.Write(ex.Message + ex.StackTrace);
}Hi DeeCan,
To bind a Grid to web service, please take a look at this help topic: asp.net-web-service-grid.htm.
I built my code based off on jqwidget examples and documentation. I am able to ‘get’ data from DB and show it in UI, but unable to edit into DB. More specifically, I am able to capture the updated values and stringify them in the script side, but unable to pass them to server side. The server update function works fine – I tested the method by setting the webservice as the start page and passing the json (from script side) as argument. What is the link between script and server code that I am missing ?
Any help will be greatly appreciated.
Regards
DeeCanScript side :
//process row data
var data = {
City: rowdata.City,
};var sendjson1 = JSON.stringify(data);
type: ‘POST’,
dataType: “json”,
data: sendjson1,
alert(xhr);
commit(true);
alert(errorThrown);
alert(textStatus);
alert(jqXHR.toString());
commit(false);
}Server side update function :
[WebMethod]
UpdateData ud = js.Deserialize(jsonobj);CustomersTableAdapter tableadapter = new CustomersTableAdapter();
}Hi DeeCan,
As far as I understand, this code
//make ajax call to server$.ajax({type: ‘POST’,url: ‘Service.asmx/UpdateCustomers’,contentType: ‘application/json; charset=utf-8′,dataType: “json”,data: sendjson1,success: function (data, status, xhr) {alert(xhr);commit(true);},error: function (jqXHR, textStatus, errorThrown) {alert(errorThrown);alert(textStatus);alert(jqXHR.toString());commit(false);}}),
is not working. My suggestion is to create a simple page with the Ajax call. I also think that .NET will automatically deserialize your JSON and that could be the reason for the failure. You can take a look at this page: http://encosia.com/asp-net-web-services-mistake-manual-json-serialization/
I got my ajax call to work, thanks to your link and a related article below :
http://encosia.com/using-complex-types-to-make-calling-services-less-complex/
Deepak -
