jQuery UI Widgets Forums Lists ListBox Help with Drag and Drop for jqxListBox items
This topic contains 2 replies, has 2 voices, and was last updated by  tekpyx 13 years ago.
  • tekpyx
    I need to be able to drag items from jqxListBox into an “contentEditable”.
    When I try the code below, events somehow stop working after the first mouse click on a list item.
    Can you please tell me what I am doing wrong, and what is the proper way of doing it ?
    From $(document).ready(function ():
    $("#jqxDockPanel").jqxDockPanel({ width: 900, height: 700, theme: theme });
    $(“#jqxMenu”).jqxMenu({ width: ‘900’, height: ’30px’, theme: theme });
    $(“#jqxMenu”).css(‘visibility’, ‘visible’);
    var source = [
    {html: “<p class=’drag’>Sentence One</p>” },
    {html: “<p class=’drag’>Sentence Two</p>” }
    $(“#jqxListBox”).jqxListBox({ source: source, width: 300, height: 650, theme: theme });
    $(“#jqxListBox”).css(‘border’, ‘none’);
    $(‘.drag’).jqxDragDrop({ dropTarget: $(‘#editor’), revert: true });
    $(‘.drag’).bind(‘mouseenter’, function (event) {
    $(‘#editor’).append(“<br>mouseenter”);
    $(‘.drag’).bind(‘mouseleave’, function (event) {
    $(‘#editor’).append(“<br>mouseleave”);
    $(‘.drag’).bind(‘dragStart’, function (event) {
    $(‘#editor’).append(“<br>dragStart”);
    $(‘.drag’).bind(‘dragEnd’, function (event) {
    $(‘#editor’).append(“<br>dragEnd”);
    $(‘.drag’).bind(‘dropTargetEnter’, function (event) {
    $(‘#editor’).append(“<br>dropTargetEnter”);
    $(‘.drag’).bind(‘dropTargetLeave’, function (event) {
    $(‘#editor’).append(“<br>dropTargetLeave”);
    Relevant HTML:
    <div id='top' dock='top' style='width: 100px; height: 50px;'
    Hi tekpyx,
    jqxListBox’s Drag and Drop functionality is still not implemented. We are currently working on this feature and it will be supported in the next version – jQWidgets 2.2.
    tekpyx
    Thank you very much, Peter, and sorry for the messed up post.
