jQuery UI Widgets › Forums › Grid › grouping and row details causing mess in column order on load state
Tagged: #jqwidgets-grid, grid, javascript grid, jquery grid
This topic contains 5 replies, has 3 voices, and was last updated by Hristo 7 years, 3 months ago.
August 23, 2017 at 9:28 am grouping and row details causing mess in column order on load state #95594
Hallo
I have a grid with group and details, and I need to save the state of the grid.
But when I load the state, the order of the columns is messed up.You can try this at jsfiddle: https://jsfiddle.net/khy6hkuy/21/
Expand at least one group, and then press the load state button,
and you will see that the order of columns is now different.This is really a serious problem, because I can not use it like this.
How can I solve this?Thank you, best regard.
Franz.Thank you, best regard.
Franz.August 24, 2017 at 2:11 pm grouping and row details causing mess in column order on load state #95632Hello Franz,
You do not have a state that to load.
http://jsfiddle.net/txhi/9u019y8h/
Also, there is another issue, thank you for the feedback.Best Regards,
Hristo HristovjQWidgets team
http://www.jqwidgets.comAugust 24, 2017 at 2:55 pm grouping and row details causing mess in column order on load state #95635Hallo Hristo
That I don’t have a state to load in my example is not correct.
I have set autosavestate=true, so when you expand at least one group, as I told you above,
there is a saved state to load, you can see in the Local Stroage an entry with key jqxGridjqxgrid and the values of the grid.In the example that you gave me (http://jsfiddle.net/txhi/9u019y8h/)
there are no details, as I told you the problem occurs when i have a grid with group and details.So I have modified your example, and there the same problem occurs.
You can try on jsfiddle: http://jsfiddle.net/9u019y8h/4/1. open a groupe
2. press Save State
3. press Load Stateand you will see that the columns order is messed up.
I need a solution for this problem.
Franz.August 25, 2017 at 11:43 am grouping and row details causing mess in column order on load state #95645Hello Franz,
Thanks again and for your assistance. I created a work item for this case.
http://www.jqwidgets.comJanuary 31, 2018 at 7:54 am grouping and row details causing mess in column order on load state #98532Hi all,
Any update on this problem?. I have the same issue and want to know if there’s a workaround or is fixed on any newest release.
Kind regards,
February 2, 2018 at 3:34 pm grouping and row details causing mess in column order on load state #98567Hello dpibt,
We cannot warranty exact date.
The work item is still valid.Best Regards,
