jQuery UI Widgets Forums Grid groupable grid – sorting problems
This topic contains 3 replies, has 2 voices, and was last updated by  Peter Stoev 11 years, 6 months ago.
  • groupable grid – sorting problems #46238
    assaf.frank123
    My grid is initialized by a JS array.
    Even though the records added to the array are in the correct order they don’t appear sorted within the group.
    I tried to manually sort the grid by – $(‘#jqxgrid’).jqxGrid(‘sortby’, ‘no’, ‘asc’);
    and this had no affect. Also making the grid – sortable:true did not sort in the correct manner.
    for exampl –
    (No,group)-
    1,A
    2,A
    3,A
    4,B,
    5,B,
    6,C
    Is shown in grid as:
    1,A
    3,A
    2,A
    4,B
    5,B
    6,C
    Is this a known issue?
    groupable grid – sorting problems #46240
    Hi assaf.frank123,
    We do not think that there’s a sorting issue when the Grid is grouped. Just make sure that the “type” member when you create the datafields array is set. In case you still experience such behavior and you use the latest (3.0.4 version), then you can provide us a sample and we’ll test it.
    groupable grid – sorting problems #46243
    assaf.frank123
    If this is what you are referring to it is set to number-
    var row_1 = {};
    row_1[“id”] = ‘123’;
    row_1[“no”] = ‘1’;
    rulesData[0] = row_1;
    var data = rulesData;
    localdata: data,
    datafields:
    { name: ‘id’, type: ‘string’},
    { name: ‘no’, type: ‘number’}
    datatype: “array”,
    I am having great trouble to try achieve what I asked in the past – “move” up/down of rows.
    Any idea how this can be done?
    Many thanks,
    groupable grid – sorting problems #46244
    Hi assaf.frank123,
    1. According to me ‘id’ and ‘no’ should be both with type ‘number’.
    2. I do not think that move up/down can be achieved with our Grid. It does not have that feature.
