jQuery UI Widgets Forums Grid Group Rendering issue
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 11 years, 1 month ago.
  • Group Rendering issue #53493
    Yogesh Singh
    I am adding rows in the grid dynamically using addrow() method and the grid is grouped
    Following is the code snipped of the grid initilizaton
    CurrentFilterGrid: function () {
    var filterGridDataAdapter = new $.jqx.dataAdapter(TC.filters.addeditviews.variables.filterGridSource);
    $(“#divFilters”).jqxGrid(
    width: ‘650’,
    height: ‘200’,
    source: filterGridDataAdapter,
    groupable: true,
    groupsexpandedbydefault: true,
    theme: TC.filters.addeditviews.variables.theme,
    showheader: false,
    showgroupsheader: false,
    localization: TC.filters.addeditviews.getLocalization(),
    { dataField: ‘VIEW_ID’, hidden: true },
    { dataField: ‘FILTER_TYPE’, hidden: true },
    { text: ”, dataField: ‘FILTER_VALUE’, width: ‘120’ },
    { text: ”, dataField: ‘FILTER_VALUE_DESCR’, width: ‘350’ },
    text: ”,
    width: ’70’,
    cellsalign: ‘center’,
    cellsrenderer: function (row) {
    return ‘<input type=”button” class=”button-link link” value=”Remove”/>’;
    groups: [‘FILTER_TYPE’],
    groupsrenderer: function (defaultText, group, state, params) {
    return “<div style=’margin: 5px;background-color: #B7C3D0′><b>” + params.subItems[0].FILTER_TYPE_DESCR + “</b></div>”;
    I am facing a strange issue that if i add the first row of the grid first group created and displays that row
    then i created another row of another group type second group created and show the row.
    then i added two more rows in the first group and now the first group contains 3 rows..
    then i removed the first row from the grid and the grouprenders the second group as first and the first group comes to the bottom of the list.
    Group Rendering issue #53497
    Hi Yogesh,
    The provided code is not sufficient for testing your scenario. Please, provide a small sample which demonstrates an issue. One thing which I noticed is that you use: params.subItems, but that is not necessary to be defined. You should check whether there are subItems or not as in our Groups Renderer demo.
